Motherboard compatible with weird PSU
Solved by aisle9,
7 minutes ago, erikeriok1 said:I have a Predator g3 710 with a 1070
PSU: liteon ps-7501-5
I want a new motherboard and how do i know what motherboard is compatible with this PSU or should i just buy a new motherboard and PSU?
Acer is the last bastion of hope for prebuilt upgraders, as they still use standard components with normal pin layouts. The PSU you have there will work just fine with any motherboard that uses a standard ATX connector.
