Windows will only boot into safe mode after sitting unused for 6+months Need help
Solved by SuperCookie78,
1 minute ago, scottyseng said:So this PC is one that was retired because the person who used it moved elsewhere and you need to get it running?
If you have an IT management company, why not let them handle it?
Otherwise if you just want to get it running, you can just install windows on it to wipe what existing OS is on the PC?
There's definitely some kind of error or conflict that's preventing windows from booting normally though.
i talked to the it managment company and he said it is just easier reinstall windows because they are using cloud computing for their programs.
