PC 0-11 Dynamic Help and fan Placement
123stephen5
Haven't gotten it yet, but considering getting this case cause i personally think it looks great and i like the way it's set up. One thing tho, i plan to have my h100i v2 and 3 case fans but i dont know how i should set them up. Also, not sure if i wanna put the radiator on the side cause its 240mm and i feel like itll just look weird there. Last thing, would it be best to do in through side then out through top, or in through bottom out throught top, or mix of the two.
