3200MHz Dual Channel VS 2933MHz Quad Channel
I just looked at the website, and it's most likely a typo. All other <64GB options are dual channel, while the other two 64GB options are quad channel. 32GB sticks don't really exist yet, so it highly likely that these are four sticks. AFAIK, there is no way to run four sticks in dual channel mode on a 4 DIMM X299 board. You can if it's a 8 DIMM board but it would be trivial to move the sticks to the correct slots to enable quad channel.
Quad channel will reduce the maximum speed and timings that you can run and increase latency compared to dual channel, but a different rated kit of memory won't be the difference between you being able to run quad channel or not. If it is not a typo, it may be Dell's strange way of saying that you may have to reduce the memory clocks to 2933Mhz in order to be stable in quad channel.
