Search In
  • More options...
Find results that contain...
Find results in...
Do those parts run great together? Compatibility?
hi,
i already have vega 64 and i want to upgrade other parts whic are i7 4790, hyperx 16GB ddr3 as im starting to struggle while gaming on my 2560x1080 monitor.
i think of getting
ryzen 5 2600
asus tuf b450 gaming plus
16GB (8x2) ballistix sport lt, number attached.
i read that dual channel bandwidth for them is around 32GBs which is low compared  to similar ram, can i overclock them with ryzen as i read they are xmp compatible with intel only.
are the rams compatible and runs well with the cpu, gpu and board? dimm, udimm, buffered, unbuffered...etc
are the rams good enough? or hyperx fury ddr4 2400mhz?
thanks
I'm not convinced that's an upgrade especially in gaming workloads. Perhaps in productivity workloads yes but it doesn't sound like you are looking for that. (Random video I found on YT as a source https://www.youtube.com/watch?v=m9wp9fomV04)
Current Desktop Build | 2200G | RX 580 4GB | 8GB RAM | CTRL | Logitech G Pro Wireless
Laptop | 2018 MBA 256/16GB | MX Master
It looks fine to me. Just update your bios and install the chipset drivers and so on and then you can run your RAM on 3000mhz, i dont think the will run stock on 3000mhz. More like on 2400. But you can enable that easy in bios. And dont turn on XMP. If your not using a aftermarket cooler. Sometimes it can heat up your cpu like crazy. On mine it went on 90° in battlefield.
11 minutes ago, Khader87 said:
that's a side grade from the 4790 at best, it may even feel slower, go 8700 or wait for zen 2.
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll evga non-3090 tie ftw3 1905 0.8v 65C 270w (double fps of 1080ti) ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll all nf12/14 fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll x27 ll PA272w
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666  bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA non-30 tie XC 1830//7600 0.85v 210w ll  8x nf12/14 fans 2x samsung 860 evo 500gb raid 0 ll 500gb nvme 970 evo ll Corsair graphite 780T ll EVGA P2 1200w ll Windows 10 Pro ll NEC PA242w (movie, work mon dying) 1080p 60hzll Predator X27 4k144 hdr (using at 4:4:4 98 fan is dying)
then why im having bad gaming performance in most games? i tried everything in the book and still bad performance, some say its due to low memory bandwidth.
what games are u playing, some games just need more cores, but if you upgrade from a 4790 or anything sandy bridge and up to a ryzen with slow memory, you are gonna be disappointed.
assassin's creedy Odyessey is unplayable, BF 5 is unplayable, company of heroes 2 is unplayable on medium settings, BO4 annoying frams drops to 50s on some maps, TW2 frame drops to 40s
all of those games need more than 4 cores, so yes, i guess if you only play those games i guess it's worth it, i still suggest waiting for zen 2 and put those games on backlog for now.
but is it normal to have 50% usage on the i7 4790 and get bad performance?
yes, some games are badly optimized, odyssey is the most demanding game atm, bf5 needs 12 threads or 8 cores minimum imo. and that game is actually optimized very well, coh can use more than 4 cores, bo4 is slightly less stressful than bfv, basically all the game u listed likes threads ?
thanks man, but are the above parts compatible ? ram with CPU and board?
i wouldn't bet on the ram being compatible, best check the motherboard qvl
 Share
