Search In
  • More options...
Find results that contain...
Find results in...
usb-hub for keyboard, mouse etc
TMobile
 Share
Go to solution Solved by fabafaba,
If it's up to the USB 2.0 standard, you won't run into a bandwidth bottleneck with your peripherals. USB 2 has about 500Mbps, which is way more than any combination of peripherals needs.
Hi,
I've been looking a some usb-hubs, to connect my (corsair) k70 lux, sabre, and void surround. I want to do this because my cable are just a little to short which hurts the cable management.
my two current options:
tp-link uh700 (7 usb-a ports)
tp-link uh720 (with two charging ports)
However I don't know if this has enough bandwidth for my peripherals, and if I therefore should look into one with usb-c.
Could you tell me if these have enough passthrough (5 gbit/s) or if I should look at usb-c hubs (and which are some good ones)
my budged is around 50 EUR, and the cable should be around 1 meter, which already decreases the amount of usb-c hubs.
Thanks!
a person with an AIO liquid cpu cooler installed on his brains.
Just Kidding
PC: Screw day theme users, I guess ¯\_(ツ)_/¯
CPU: R9 3900X @ 4.375GHz All Core MoBo: ASRock X470 Taichi RAM: 4×8GB HyperX Fury @ 3200MHz 16-18-18-35 GPU: 2x GTX 1080TI FE @ 2088MHz Cooling: Single 60x360mm rad, dual 45x540mm external rad, Nickel Plexi EKWB blocks, Scythe Kaze Flex 140, Alphacool VPP755V3 + Watercool Heatkiller Tube 250, Aquacomputer Quadro Case: Inter-Tech 4U 4129-N PSU: Corsair RM1000x Storage: 250GB 970Evo, 1TB Seagate Barracuda  Q1 SSD Network: Mellanox ConnectX-3 10G
NAS:
CPU:  i7 6850K MoBo: MSI X99A SLI Plus RAM: 2×8GB GSkill Aegis @ 2666MHz GPU: GT730 Cooling: 4xNoiseblocker NB-BlackSilentFan 80mm, Supermicro 2U Passive Cooler with a 60mm Noctua fan stuck on Case: Rackmax RM-2108-660-HT 8 Bay PSU: be quiet! TFX Power 2 300W Storage: 4x2TB Seagate Ironwolf + 2x120GB SSD Network: Mellanox ConnectX-3 10G
VM_Host:
CPU:  i5 10600K MoBo: MSI MPG Z490 Gaming Plus RAM: 2×16GB Mushkin Redline @ 3200MHz 16-18-18-38 GPU: - Cooling: Single 30x360mm rad, Nickel Plexi EKWB CPU Block, Corsair ML120, Alphacool VPP755V3 + Watercool Heatkiller Tube 250, Aquacomputer Aquaero 5LT Case: Inter-Tech 3U 30255 PSU: Seasonic M12-II Evo 850W Storage: 512GB Patriot P300 Network: Intel Quad 1G
Laptop: Acer Travelmate B117 (absolutely low power, but 12h battery life :D)
Phone: Oneplus 2 64GB
Peripherals:
Monitor: LG 34UC79G + 27GL63T Keyboard: Corsair K63 Wireless Mouse: Logitech G603 Mousepad: Cheap-ass GMB Mouspad Headphones: AKG K7XX  Other stuff: Novation Launchpad MK2, Aune T1 USB DAC/Amp, Behringer UMC202HD + Audio Technica AT2020 Condenser Mic
Cameras:
DSLR: Canon EOS 600D (Magic Lantern OS) Action Cam: GoPro Hero 3 Silver
Mountainbike:
Frame: Banshee Legend MKIII Fork: Marzocchi 380 C2R2 Titanium Rear shock: Rock Shox Vivid Air/Coil (switched depending on how I feel) Wheels: Spank Spike Race 33 Tires: Maxxis Minion DHR2/DHF Brakes: Magura MT5 Calipers with Shimano XT Levers Deraileur: Shimano Zee, Casette reduced to 6 Speed Crankset: Truvativ Descendant + 38T FSA Chainring Wheight: 16.4kg w/o pedals
okay, thanks alot man :)
btw: its 3.0
Just Kidding
 Share
