Search In
  • More options...
Find results that contain...
Find results in...
Basic fans question for b450m pro4 mobo and best solution
Hello guys my question is pretty basic.
I purchased Asrock b450m pro4 and it has :
1 x CPU Fan Connector (4-pin)
1 x CPU/Water Pump Fan Connector (4-pin)
3 x Chassis/Water Pump Fan Connectors (4-pin)
So i plan to use 3 fans for intake, 1 for exhaust and my question is would you recommend 1 of chassis headers for exhaust and the other 2 for 2 of my intake ones and the last one plugged into the CPU/Water Pump Fan Connector or leave that free and buy splitter and just use 1 header for 2 fans.
It doesn't matter, you can control the speeds on all of them with some software. If you use the second CPU fan header, it will just follow the speed of the first CPU fan header.
My Build, v2.1 --- CPU: i7-8700K @ 5.2GHz/1.288v || MoBo: Asus ROG STRIX Z390-E Gaming || RAM: 4x4GB G.SKILL Ripjaws 4 2666 14-14-14-33 || Cooler: Custom Loop || GPU: EVGA GTX 1080 Ti SC Black, on water || PSU: EVGA G2 850W || Case: Corsair 450D || SSD: 850 Evo 250GB, Intel 660p 2TB || Storage: WD Blue 2TB || G502 & Glorious PCGR Fully Custom 80% Keyboard || MX34VQ, PG278Q, PB278Q
Audio --- Headphones: Massdrop x Sennheiser HD 6XX || Amp: Schiit Audio Magni 3 || DAC: Schiit Audio Modi 3 || Mic: Blue Yeti
[Under Construction]
My Truck --- 2002 F-350 7.3 Powerstroke || 6-speed
My Car --- 2006 Mustang GT || 5-speed || BBK LTs, O/R X, MBRP Cat-back || BBK Lowering Springs, LCAs || 2007 GT500 wheels w/ 245s/285s
The Experiment --- CPU: i5-3570K @ 4.0 GHz || MoBo: Asus P8Z77-V LK || RAM: 16GB Corsair 1600 4x4 || Cooler: CM Hyper 212 Evo || GPUs: Asus GTX 750 Ti, || PSU: Corsair TX750M Gold || Case: Thermaltake Core G21 TG || SSD: 840 Pro 128GB || HDD: Seagate Barracuda 2TB
R.I.P. Asus X99-A motherboard, April 2016 - October 2018, may you rest in peace. 5820K, if I ever buy you a new board, it'll be a good one.
You can also use all your intakes on one chassis fan header using a splitter, doesn't matter.
I would use a splitter, then you can control all the input fans at once, no need for creating multiple curves, and then have the outtake on a different header.
I only see your reply if you @ me.
 Share
