Monitor Inquiry (VA/IPS)
Loxa
Current Monitors:
BenQ XL2411T(Main)
LG E2351(Second)
I have been racking my brain for a few weeks now trying to choose a new monitor (VA/IPS), i was pretty much set on a MPG27CQ but then realised VA panels have a really bad issue with ghosting which i would not find acceptable as all i do on my computer is game. I then started to look more in to IPS Panels but as most of us already know the lowest ms on IPS is 4ms, so my question is how does 4ms(IPS) hold up against 1ms(TN).
Anymore information about VA panels would also be appreciated but it seems you can not escape ghosting on these models.
Rig: 5950X | ROG VIII Formula | 6900XT
Laptop: 5900HX | 6800M | 16GB
I have a 100 Hz VA panel. It is noticeably lower quality than my 144Hz TN panel, and I can guarantee it's not solely because of refresh rate, I think just it being a VA panel. I've never owned a high refresh rate IPS panel but I've used a few and they have no noticeable difference compared to a TN, IMO. Refresh rate is probably one of the lesser important qualities of a monitor, and supposedly there's no standardized way of testing it either. I just go with 5ms or lower and call it good enough. I would take a good IPS any day over a good TN. But this is all subjective, everyone has different eyes, and likes different things.
My Build, v2.1 --- CPU: i7-8700K @ 5.2GHz/1.288v || MoBo: Asus ROG STRIX Z390-E Gaming || RAM: 4x4GB G.SKILL Ripjaws 4 2666 14-14-14-33 || Cooler: Custom Loop || GPU: EVGA GTX 1080 Ti SC Black, on water || PSU: EVGA G2 850W || Case: Corsair 450D || SSD: 850 Evo 250GB, Intel 660p 2TB || Storage: WD Blue 2TB || G502 & Glorious PCGR Fully Custom 80% Keyboard || MX34VQ, PG278Q, PB278Q
Audio --- Headphones: Massdrop x Sennheiser HD 6XX || Amp: Schiit Audio Magni 3 || DAC: Schiit Audio Modi 3 || Mic: Blue Yeti
[Under Construction]
My Truck --- 2002 F-350 7.3 Powerstroke || 6-speed
My Car --- 2006 Mustang GT || 5-speed || BBK LTs, O/R X, MBRP Cat-back || BBK Lowering Springs, LCAs || 2007 GT500 wheels w/ 245s/285s
The Experiment --- CPU: i5-3570K @ 4.0 GHz || MoBo: Asus P8Z77-V LK || RAM: 16GB Corsair 1600 4x4 || Cooler: CM Hyper 212 Evo || GPUs: Asus GTX 750 Ti, || PSU: Corsair TX750M Gold || Case: Thermaltake Core G21 TG || SSD: 840 Pro 128GB || HDD: Seagate Barracuda 2TB
R.I.P. Asus X99-A motherboard, April 2016 - October 2018, may you rest in peace. 5820K, if I ever buy you a new board, it'll be a good one.
I am leaning more and more towards a "Acer XB271HUB" over the "MSI MPG27CQ" as the reviews seem very reasonable and not much mention of ghosting/trailing, just the matter of playing the BLB lottery with an IPS which seems ridiculous but...
From what i have seeen tested, Most TN panels find it hard to hit 4ms 100% pixel transition speed.
However, Manufactuers, whome all use different testing methodologies (this is why u ignore maufacture specs), are almost certianly stating 80% transition speeds.
For IPS, the best ones i've seen have 2.8ms - 3.5ms 80% speed and 7.8ms and 13ms 100% transition speeds.
For VA, the best ones i've seen have  2.8ms - 5ms 80% speed and 10.9 -13ms 100% speed.
For reference TN have around 2ms - 4ms 80% speeds and 4-10ms 100% speeds.
There differnce isnt huge in numbers but does make a difference in practice. idealy u want to ensure your 100% speed is below that of the frame time of monitor, so 144hz is 6.9ms, which is why u should get a TN panels at that refresh rate.
CPU: Intel i7 3930k w/OC & EK Supremacy EVO Block | Motherboard: Asus P9x79 Pro  | RAM: G.Skill 4x4 1866 CL9 | PSU: Seasonic Platinum 1000w Corsair RM 750w Gold (2021)|
VDU: Panasonic 42" Plasma | GPU: Gigabyte 1080ti Gaming OC & Barrow Block (RIP)...GTX 980ti | Sound: Asus Xonar D2X - Z5500 -FiiO X3K DAP/DAC - ATH-M50S | Case: Phantek Enthoo Primo White |
Storage: Samsung 850 Pro 1TB SSD + WD Blue 1TB SSD | Cooling: XSPC D5 Photon 270 Res & Pump | 2x XSPC AX240 White Rads | NexXxos Monsta 80x240 Rad P/P | NF-A12x25 fans |
