corsair tx650m PSU vs corsair 275r case
Solved by Stefan Payne,
9 hours ago, 2018amdbuild said:Hi, does anyone have a guide for screwing in the PSU (in this case the corsair tx650m) into the Corsair 275r case, in particular which screws are required? unfortunately the booklet guide with it aren't very in depth.
Its the normal standard Imperial crap, not the good metric ones...
Don't use the long ones but the shorter ones...
