Search In
  • More options...
Find results that contain...
Find results in...
Corsair ML140 Voltage Question
jiyeon
 Share
Hi, so I'm after some new fans, specifically the Corsair ML140 fans for the front of my NZXT S340.
However, on the Amazon page, it says this:
Quote
Note: ML fans require a constant 12V in order to lift the bearing for it to spin. Do not use using a fan controller that is voltage regulated and not supplying 12V.
I use a fan splitter already for the 2 front fans of my case, so I'd be using that same 1-to-2 fan splitter for my new Corsair ML140 fans. I currently use Corsair SP120 RGB fans at the moment.
I was wondering if it's alright if I used the fan splitter to power the Corsair ML140 fans?
mechanical keyboard switches aficionado & hi-fi audio enthusiast
switch reviews  how i lube mx-style keyboard switches
4pin splitter is fine, 3pin are not (unless you run them full speed all the time)
Model: HP Omen 17 17-an110ca CPU: i7-8750H (0.125V core & cache, 50mV SA undervolt) GPU: GTX 1060 6GB Mobile (+80/+450, 1650MHz~1750MHz 0.78V~0.85V) RAM: 8+8GB DDR4-2400 18-17-17-39 2T Storage: 1TB HP EX920 PCIe x4 M.2 SSD + 1TB Seagate 7200RPM 2.5" HDD (ST1000LM049-2GH172), 128GB Toshiba PCIe x2 M.2 SSD (KBG30ZMV128G) gone cooking externally Monitor: 1080p 126Hz IPS G-sync
Desktop benching:
5 minutes ago, seoz said:
It's a 4-pin that slaves into a 3-pin, is that alright for an ML140?
it's fine. That still count as a PWM connector even though it lacks a pin (that's for detecting speed),
Desktop benching:
That splitter is fine, but more importantly, the ML fans require a PWM signal source as well. You'll need to drive them from either a PWM enabled header on the motherboard or a PWM controller.
EDIT: As mentioned by @Jurrunio, if the fans ARE plugged into a 3-pin source, you need to make sure they are fed 12V, which will make them stay at full speed, but that also means they'd be rather loud.
CPU: AMD Sempron 2400+ / MOBO: Abit NF7-S2G / GPU: WinFast A180BT 64MB / RAM: Mushkin DDR333 256MBx2 / HDD: Seagate Barracuda 7200RPM 120GB
I made a quick pic of how it would work in theory, I'm still concerned that the second fan wouldn't be getting enough power.
just make sure the sum of current ratings don't exceed 1A
Desktop benching:
So 4-pin mobo header, perfect. Just make sure in BIOS that the fan header is set to PWM mode when switching fans if it has the option, especially if your SP120s are running at less than full speed currently. The "second" connector on the splitter still supplies the same power, the missing pin is only for RPM reporting. There's an issue with boards receiving two RPM signals on one header so the splitter omits one fan, reports the speed of the "first".
 Share
