Search In
  • More options...
Find results that contain...
Find results in...
Building PC for WORK at HOME | Heavy Multi Tasking
Srinivas Y
 Share
Hi,
I am planning to build a PC for work. Mostly I will have to run the simulators and emulators for mobile app development (Virtual Box, XCode, Android Studio etc). Also I need to work on many other development tools which include working with huge spreadsheet files. I will not be doing Video editing. I am not interested in gaming. Consider as basic entry level gamer. Below is the parts list I am thinking of. Please suggest changes/improvements.
CPU: AMD Ryzen 7 2700x
Motherboard: ASUS ROG STRIX B450-F GAMING
RAM: GSKILL F4 3200MHZ DESKTOP RAM RIPJAWS V SERIES 4 X 8GB
MEMORY: SAMSUNG 970 EVO 250GB M.2 NVME INTERNAL SSD
CABINET: CORSAIR SPEC 3(ATX) MID TOWER CABINET
PSU: CORSAIR CX650M SMPS
GPU: ASUS GRAPHIC CARD GT 1030 2GB DDR5 PHEONIX OC EDITION
This is my first CPU build. Not interested in overclocking and liquid cooling systems. For storage I already have around 1TB HDD.
Please help.
Not sure if you need all those cores, but I'm using the 2600X and I'm in web development (running lots of programs at once, and running local servers) and it does it all just fine with lots of room to spare. I say this because if you don't need the 2700X (it's not noticeably faster), then I would get the 2600X and use leftover money for a better GPU, even though you're not gaming, it can come in handy at times. If you can afford a better GPU and the 2700X then by all means, I think you should get a better one either way..
Ryzen 3800X + MEG ACE w/ Radeon VII + 3733 c14 Trident Z RGB in a Custom Loop powered by Seasonic Prime Ultra Titanium
PSU Tier List | Motherboard Tier List | My Build
The extra cores are nice for VMs though.
You might want to get an additional HDD to run them in a mirrored configuration, unless you're working off a server or NAS. Other than that I don't see any problems with your choice of parts.
PC: Screw day theme users, I guess ¯\_(ツ)_/¯
CPU: R9 3900X @ 4.375GHz All Core MoBo: ASRock X470 Taichi RAM: 4×8GB HyperX Fury @ 3200MHz 16-18-18-35 GPU: 2x GTX 1080TI FE @ 2088MHz Cooling: Single 60x360mm rad, dual 45x540mm external rad, Nickel Plexi EKWB blocks, Scythe Kaze Flex 140, Alphacool VPP755V3 + Watercool Heatkiller Tube 250, Aquacomputer Quadro Case: Inter-Tech 4U 4129-N PSU: Corsair RM1000x Storage: 250GB 970Evo, 1TB Seagate Barracuda  Q1 SSD Network: Mellanox ConnectX-3 10G
NAS:
CPU:  i7 6850K MoBo: MSI X99A SLI Plus RAM: 2×8GB GSkill Aegis @ 2666MHz GPU: GT730 Cooling: 4xNoiseblocker NB-BlackSilentFan 80mm, Supermicro 2U Passive Cooler with a 60mm Noctua fan stuck on Case: Rackmax RM-2108-660-HT 8 Bay PSU: be quiet! TFX Power 2 300W Storage: 4x2TB Seagate Ironwolf + 2x120GB SSD Network: Mellanox ConnectX-3 10G
VM_Host:
CPU:  i5 10600K MoBo: MSI MPG Z490 Gaming Plus RAM: 2×16GB Mushkin Redline @ 3200MHz 16-18-18-38 GPU: - Cooling: Single 30x360mm rad, Nickel Plexi EKWB CPU Block, Corsair ML120, Alphacool VPP755V3 + Watercool Heatkiller Tube 250, Aquacomputer Aquaero 5LT Case: Inter-Tech 3U 30255 PSU: Seasonic M12-II Evo 850W Storage: 512GB Patriot P300 Network: Intel Quad 1G
Laptop: Acer Travelmate B117 (absolutely low power, but 12h battery life :D)
Phone: Oneplus 2 64GB
Peripherals:
Monitor: LG 34UC79G + 27GL63T Keyboard: Corsair K63 Wireless Mouse: Logitech G603 Mousepad: Cheap-ass GMB Mouspad Headphones: AKG K7XX  Other stuff: Novation Launchpad MK2, Aune T1 USB DAC/Amp, Behringer UMC202HD + Audio Technica AT2020 Condenser Mic
Cameras:
DSLR: Canon EOS 600D (Magic Lantern OS) Action Cam: GoPro Hero 3 Silver
Mountainbike:
Frame: Banshee Legend MKIII Fork: Marzocchi 380 C2R2 Titanium Rear shock: Rock Shox Vivid Air/Coil (switched depending on how I feel) Wheels: Spank Spike Race 33 Tires: Maxxis Minion DHR2/DHF Brakes: Magura MT5 Calipers with Shimano XT Levers Deraileur: Shimano Zee, Casette reduced to 6 Speed Crankset: Truvativ Descendant + 38T FSA Chainring Wheight: 16.4kg w/o pedals
 Share
