$2200 Build final checks
7 hours ago, cs117x said:should I completely not use AIOs then even if I'm willing to spend the extra money on a more expensive one?
Nothing wrong with using an aio, especially if one wants to show off the motherboard. Rather than the two additional fans, why not get a 2x140mm aio. It will provide much better cooling and mounted in the font will improve airflow.
CPU coolers come with either a pre-applied pad or tube of thermal compound. There is generally little need for additional or different compound.
I would use a 2x16GB memory kit. This would leave two slots free for upgrading should that ever be necessary.
Consider simplifying storage by going with a single ssd.
I'd suggest a slightly higher capacity psu.
CPU: AMD - Ryzen 7 2700X 3.7 GHz 8-Core Processor (£294.40 @ Alza)
CPU Cooler: NZXT - Kraken X62 Rev 2 98.17 CFM Liquid CPU Cooler (£134.66 @ Amazon UK)
Motherboard: Asus - ROG STRIX X470-F Gaming ATX AM4 Motherboard (£190.40 @ Alza)
Memory: Corsair - Vengeance LPX 32 GB (2 x 16 GB) DDR4-3000 Memory (£229.99 @ Amazon UK)
Storage: Samsung - 860 Evo 1 TB 2.5" Solid State Drive (£154.97 @ Ebuyer)
Video Card: Sapphire - Radeon RX VEGA 64 8 GB NITRO+ Video Card (£439.79 @ Overclockers.co.uk)
Case: NZXT - H500 (White) ATX Mid Tower Case (£71.66 @ CCL Computers)
Power Supply: Corsair - RMx (2018) 650 W 80+ Gold Certified Fully-Modular ATX Power Supply (£87.98 @ CCL Computers)
Monitor: Asus - MG279Q 27.0" 2560x1440 144 Hz Monitor (£428.99 @ Box Limited)
Total: £2032.84
Generated by PCPartPicker 2018-12-15 18:14 GMT+0000
