Wifi card in the way of graphic card fan
Solved by r2724r16,
4 minutes ago, thebootsie123 said:Sapphire Nitro+ RX 580
I bought two of those a few months back and they're big cards, you'll need quite a bit of clearance for them.
5 minutes ago, thebootsie123 said:I was thinking of possibley 3D printing a part to act as a table to keep the graphics card up which lifts it up enough so that the fan can freely spin.
You don't need to 3D print a part, you can just throw in any object that can hold the video card up.
BTW, why do you have a PCIe NIC? Doesn't your motherboard have a Gigabit LAN port?
