Case Fans slow down or stop
Solved by meenmeen1103,
If all three exhibit the same problem at once, then it's not the fans themselves. Sounds like a control module issue. If re-seating all connections to the control box doesn't fix it, probably no easy fix for it.
da na ·
Posted in General Discussion1 -
1
Russsell ·
Posted in Networking2 -
3
4
2
resonate ·
Posted in Laptops and Pre-Built Systems0
play_circle_filled
Latest From Linus Tech Tips:
The BRIGHTEST Monitor We've EVER Seen - Sun Vision rE rLCD Display
play_circle_filled
Latest From ShortCircuit:
The World's Fastest CPU (Technically...) - Intel i9-14900KS
