Search In
  • More options...
Find results that contain...
Find results in...
Asrock ab350 pro4 + ryzen 5 2600
 Share
Hello! I am doing a build for my friend. And I know that in April, there was a compatibility issue with Ryzen 5 2600 and a 350 mobo due to the lack of bios update. What I am curious of is whether or not these past months were enough for them to upgrade the mobo. Please don’t tell me to get another mobo or another processor, remain on the topic.
  • CPU
    Ryzen 5 1600 OC 3,7ghz
  • Motherboard
    ASrock AB350 Pro4 ATX
  • RAM
    A-Data 2666mhz upgraded to Corsair LPX 2x8gb 3000mhz
  • GPU
    GTX 1060 6gb
  • Case
    Segotep Chariot TF
  • Storage
    1TB HDD, 240gb M.2 Intel NVMe SSD
  • PSU
    Evga 600w B+
  • Display(s)
    Samsung Full HD 24' Free sync
  • Cooling
    3x 120mm case fans
  • Keyboard
    Razer BlackWidow Chroma V2
  • Mouse
    Razer DeathAdder Elite
  • Sound
    Razer Kraken Pro
  • Operating System
    Windows 10 Pro
If you're buying it new it probably has support right out of the box. If not you'll need a 1st gen Ryzen chip to flash the BIOS.
AMD might still be doing their program where they would give you a CPU on loan and you ship it back once you've updated.
Laptop: 2019 16" MacBook Pro i7, 512GB, 5300M 4GB, 16GB DDR4 | Phone: iPhone 13 Pro Max 128GB | Wearables: Apple Watch SE | CPU: R5 2600 | Mobo: ASRock B450M Pro4 | RAM: 16GB 2666 | GPU: ASRock RX 5700 8GB | Case: Apple PowerMac G5 | OS: Win 10 | Storage: 480GB PNY SSD & 2TB WD Green HDD | PSU: Corsair CX600M | Display: Dell 27 Gaming Monitor S2719DGF 1440p @155Hz, Dell UZ2215H 21.5" 1080p, ViewSonic VX2450wm-LED 23.6" 1080p | Cooling: Wraith Prism | Keyboard: G610 Orion Cherry MX Brown | Mouse: G303 | Audio: Audio Technica ATH-M50X & Blue Snowball
If it's new you can always ask the seller. But chances are it's already running the latest bios
Ryzen 5 1600 @ 3.9 Ghz  | Gigabyte AB350M Gaming 3 |  PaliT GTX 1050Ti  |  8gb Kingston HyperX Fury @ 2933 Mhz  |  Corsair CX550m  |  1 TB WD Blue HDD
Inside some old case I found lying around.
It is new and it has the sticker on it, though it might refer to the raven ridge only
  • CPU
  • Motherboard
  • RAM
  • GPU
    GTX 1060 6gb
  • Case
    Segotep Chariot TF
  • Storage
  • PSU
    Evga 600w B+
  • Display(s)
  • Cooling
    3x 120mm case fans
  • Keyboard
  • Mouse
  • Sound
    Razer Kraken Pro
  • Operating System
    Windows 10 Pro
I’m going to ask the seller thanks!
  • CPU
  • Motherboard
  • RAM
  • GPU
    GTX 1060 6gb
  • Case
    Segotep Chariot TF
  • Storage
  • PSU
    Evga 600w B+
  • Display(s)
  • Cooling
    3x 120mm case fans
  • Keyboard
  • Mouse
  • Sound
    Razer Kraken Pro
  • Operating System
    Windows 10 Pro
 Share
