Search In
  • More options...
Find results that contain...
Find results in...
CPU Fans are not spinning
Fevziye
 Share
The pc boots fine. everything is fine. but the CPU fans are not spinning by themselves. if I move them manually they start spinning as they should be. so the fans are getting power. but other times. they don't. what do you guys think might be wrong with it?
i tried stress testing the cpu to see if they start spinning as the cpu temp gets higher. (went to 69 c highest on the stress test). still nothing.
on idle it stays 45-50 c
on load its 60-70 max
i5 2500k on stock clock. using some Noctua cooler (forgot name) with dual fans
They arent receiving enough power to break static friction?
Model: HP Omen 17 17-an110ca CPU: i7-8750H (0.125V core & cache, 50mV SA undervolt) GPU: GTX 1060 6GB Mobile (+80/+450, 1650MHz~1750MHz 0.78V~0.85V) RAM: 8+8GB DDR4-2400 18-17-17-39 2T Storage: 1TB HP EX920 PCIe x4 M.2 SSD + 1TB Seagate 7200RPM 2.5" HDD (ST1000LM049-2GH172), 128GB Toshiba PCIe x2 M.2 SSD (KBG30ZMV128G) gone cooking externally Monitor: 1080p 126Hz IPS G-sync
Desktop benching:
wdym
What brand and model are the CPU fans? You mentioned Noctua but is that just the heatsink or is that the whole cooling combo? How long have you had the fans for?
It could well be a power deliver issue like @Jurrunio mentioned, could be an internal fan controller issue or perhaps the cable pins are lose. Have you had any physical changes to the system or fans lately, or have they been working just fine up until when this problem arose?
14 minutes ago, Fevziye said:
wdym
Do they spin fast after a manual push start?
Desktop benching:
yes, after i manually move the fans they start spinning fast. if they are not receiving power then they shouldn't, right?
Yes, it requires power to keep spinning but even more power to start up. What fans are you using and what header are they being powered off of? If they're plugged into the motherboard, tell us which headers and on what motherboard.
Gigabyte Z68XP-UD4
5 hours ago, Fevziye said:
Gigabyte Z68XP-UD4
Have you tried using other headers? What profile or control setup you are using?
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
Maybe its meant to be man.  Its not a big deal, just give the fans a nudge and off they go LOL.  no but seriously this blows goat.  How can both fans behave like this hmmm. something smells fishy...
Asus Sabertooth x79 / 4930k @ 4500 @ 1.408v / Gigabyte WF 2080 RTX / Corsair VG 64GB @ 1866 & AX1600i & H115i Pro @ 2x Noctua NF-A14 / Carbide 330r Blackout
Scarlett 2i2 Audio Interface / KRK Rokits 10" / Sennheiser HD 650 / Logitech G Pro Wireless Mouse & G915 Linear & G935 & C920 / SL 88 Grand / Cakewalk / NF-A14 Int P12 Ex
AOC 40" 4k Curved / LG 55" OLED C9 120hz / LaCie Porsche Design 2TB & 500GB / Samsung 950 Pro 500GB / 850 Pro 500GB / Crucial m4 500GB / Asus M.2 Card
i don't understand what that means ;-;
Have you tested that this only happens with these fans and on CPU fan header? And have you changed control options from BIOS?
I will try to control options from bios and let you know.
 Share
