Cooler Master Fan Config help
vjizzle2384
My case has is Cooler Master MB500
Am getting a 240 mm AIO Liquid Cooler for this case now when I bought it I thought it had space to mount a radiator on the top.  This only has space for it to have one in the front so my question is how do I configure fans from the radiator push or pull? And where will i my case fans for intake and exhaust ?
88CEB19B-394C-42EF-AF2F-563AA1F42505.thumb.jpeg.0f5444cf47fe7cbb39ee4331309962d4.jpegE52451F3-ABA1-4318-AF4E-D3D1359E260A.thumb.png.a3453468cdd33c5cf51de8029c0d1809.png
My PC:
CPU: AMD Ryzen 5 2600X Processor (4.4Ghz), MOBO: GIGABYTE X470 AORUS Gaming 7 WiFi (AMD Ryzen AM4/ X470/ Intel Wave 2 WiFi/M.2), RAM: Corsair Vengeance LPX 16GB (2x8GB) DDR4 DRAM 3000MHz C15, GPU: Gigabyte nVidia GeForce GTX 1080 Windforce OC GV-N1080WF3OC-8GD Graphics Cards, STORAGE: 120GB CRUCIAL SSD, 1TB WD BLUE, COOLER: Cooler Master 212 EVO RGB Black Edition, FANS: 4 x MasterFan MF120R RGB (2 Front, 1 Back, 1 Top), 1 x Noctua NF-P12 Redux 1700 RPM(Back off Cooler), PC CASE: Cooler Master MB500 case, PSU: EVGA 750 BQ.
My Kids PC:
CPU: AMD Phenom II x4 955 (95watt @3.5Ghz @1.40V), MOBO: ASUS M2A-VM, RAM: Kingston 8GB (4x2GB) DDR2 800MHz, GPU: nVidia GT 710 2GB DDR3 (OC’ed Clock to 1300Mhz and Memory to 950Mhz), STORAGE: 250GB HDD, 500GB HDD, COOLER:  Cooler Master 212 EVO, PC CASE: Cooler Master Q300L , FANS: 3 x upHere RED LED Fans (2 Front, 1 Back), PSU: Generic 300 Watt PSU.
Console:  PS4 - vjizzle2384
I really need help on this
My PC:
My Kids PC:
The first picture that you posted is the ideal airflow configuration you want.
Front fans are intake, and the rear + top are exhaust.
As for setting up the radiator fans as either push or pull, that will not matter.
Personally, I would go for a push configuration for the radiator.
Intel Z390 Rig ( *NEW* Primary )
Intel X99 Rig (Officially Decommissioned, Dead CPU returned to Intel)
  • i7-8086K @ 5.1 GHz (still tweaking) -- i7-6800K
  • Gigabyte Z390 Aorus Master -- ASUS X99 Deluxe
  • Sapphire NITRO+ RX 6800 XT Special Edition Sapphire NITRO+ RX 5700 XT Special Edition -- 2x Sapphire NITRO R9-Fury in Crossfire
  • 32GB G.Skill TridentZ DDR4-3000 CL14 (16GB TridentZ RGB + 16GB Red/Black TridentZ)
  • SanDisk 480 GB SSD + 1TB Samsung 860 EVO + 1TB WD SN750
  • EVGA SuperNOVA 850W P2 + Red/White CableMod Cables
  • Phanteks Enthoo Luxe Tempered Glass Edition
  • Ekwb Custom loop
  • Logitech G502 Proteus Spectrum + Corsair K70 (Red LED, anodized black, Cheery MX Browns)
AMD Ryzen Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
Intel Z97 Rig (Decomissioned)
  • Intel i5-4690K 4.8 GHz
  • ASUS ROG Maximus VII Hero Z97
  • Sapphire Vapor-X HD 7950 EVGA GTX 1070 SC Black Edition ACX 3.0
  • 20 GB (8GB X 2 + 4GB X 1) Corsair Vengeance DDR3 1600 MHz
  • Corsair A50 air cooler  NZXT X61
  • Crucial MX500 1TB SSD + SanDisk Ultra II 240GB SSD + WD Caviar Black 1TB HDD + Kingston V300 120GB SSD [non-gimped version]
  • Antec New TruePower 550W EVGA G2 650W + White CableMod cables
  • Cooler Master HAF 912 White NZXT S340 Elite w/ white LED stips
AMD 990FX Rig (Decommissioned)
  • FX-8350 @ 4.8 / 4.9 GHz (given up on the 5.0 / 5.1 GHz attempt)
  • ASUS ROG Crosshair V Formula 990FX
  • 12 GB (4 GB X 3) G.Skill RipJawsX DDR3 @ 1866 MHz
  • Sapphire Vapor-X HD 7970 + Sapphire Dual-X HD 7970 in Crossfire  Sapphire NITRO R9-Fury in Crossfire *NONE*
  • Thermaltake Frio w/ Cooler Master JetFlo's in push-pull
  • Samsung 850 EVO 500GB SSD + Kingston V300 120GB SSD + WD Caviar Black 1TB HDD
  • Corsair TX850 (ver.1)
  • Cooler Master HAF 932
Where will I have intake at if the radiator pushs air out the front
My PC:
My Kids PC:
I have this case, with a 360mm AIO mounted in the front location, and the fans are mounted in the same location as the stock fans come on the on out side of the front frame behind the front plastic panel.
2 top exhaust fans, 1 rear exhaust
CPU ~ i7 8700k @ 5.0ghz 1.285v | Motherboard ~ Gigabyte Z370 Aorus Gaming 5 | Cooler ~ CoolerMaster ML360R (With Corsair ML120 fans)
RAM ~ 16gb G.Skill Sniper X 3000mhz | GPU ~ Nvidia RTX 2080 FE | PSU ~ Corsair RM1000x | Case ~ CoolerMaster MB500
Top, but I would advice against front exhaust. Your GPU will lack airflow, since you can't have bottom intake. It's better to keep front as intake. Temps for GPU will still be higher than when having rad at top, but better than without almost any direct airflow.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
 So you absolutely have no intake is your intake coming into the front bringing warm air from the radiator and be exhaust from the top and back?
My PC:
My Kids PC:
NO intake? intake is from the front, pushing air thru the radiator in to the case.
The radiator does not generate that much hot air to effect anything in side the case. My temps here with avg room temp of 25c, at gaming load playing say PUBG, 61c GPU 55c CPU 8700k at 5ghz.
Here man, this is how all my fans are mounted. I have found this to be the best set up. I have also tried push pull with 3 exhaust fans with radiator in same location and it rendered the same temps. This PC while gaming you can hear the fans but while doing anything else is dead silent.
Yeah I don’t game without a headphones and mine are noise canceling so I could never hear noise outside my headphones for the fan noise t. make a difference to me.
thank you for showing me your set up this helps me a lot, I’m just still confused how the radiator doesn’t produce that much heat guessing because you have a 360 mm,  My buddy has the same liquid cooler as you but 240mm and his blows hot air while gaming.
My PC:
My Kids PC:
He means that rad doesn't raise temps so much that it would be worse for GPU than having top as intake. Also having rad as intake will have better CPU temps so it's win-win. But if you don't believe us, you can very easily run your own testing.
It has nothing to do with believing you guys, it just confusing to me.   So should I just make my set up like his the rad in front as intake and the one back fan and two top fans as exhaust. And you were saying as for my GPU it will get little more hotter the usually, my game Gpu temps are no higher than 65c and same with CPU on ultra.
My PC:
My Kids PC:
I would recommend running a custom GPU fan curve with MSI Afterburner, as my FE card is not very loud, i have mine running 100%  fan after 60c.
If you ever have time could you take a screenshot of your GPU fan curve to give me a reference thank you
My PC:
My Kids PC:
47317636_277360229590463_7809673307879374848_n.jpg?_nc_cat=104&_nc_ht=scontent.fsyd6-1.fna&oh=fcf0016b95d2a4968dc7c652300b3be8&oe=5C914EBB
Thank you so much for your help and taking the time to give me a screenshot one more question what liquid color are you using is it the ML360R RGB?
oh check this pc cooling thought you’d get a kick out the of it..
My PC:
My Kids PC:
All good mate, that what this forum is here for to help out.
Yeah I have the CoolerMaster ML360R RGB, running Corsair ML120 fans
If it was you what would you get a Dark Rock Pro 4 or ml240r or ml360r for my 2600x?
My PC:
My Kids PC:
Depends on what you want.
I use to have the CoolerMaster MA620P, which is a 200w twin tower air cooler, only went to the 360 aio as I wanted the 8700k at 5ghz.
For the 2600x, you could go any one of them options and still get about the same performance. The MB500 will fit a air cooler up to 165mm even tho the website states 160mm.
Before I went with the 360mm AIO i was looking at the Dark Pro 3/4, Noctua D15 and the Cryorig R1.
It all comes down to what you want, I like air coolers, but with limited space i went with AIO.
 I’ve made my choice between dark pro 4, New Masterliquid 240 RGB (When I can find it) or New Black Noctua D15(Waiting for its release)
My PC:
My Kids PC:
