Search In
  • More options...
Find results that contain...
Find results in...
4K Monitor for PS4 Pro
peep
 Share
Looking for a 4K (UHD?) monitor for the PS4 Pro, I'm going for looks so ips panel would be preferred, but not sure if it fits into the £300-£400 price range. I'm going to be playing graphical games like God of War, Spiderman, Assassins Creed etc. Also, does anyone know what happens if you play a PS4 game with a default resolution lower than your monitor's resolution? Does it upscale and look ugly? Because I'm going to be playing games like Hollow Knight and Bully that don't support 4K. Thanks!
8 minutes ago, peep said:
It will be fine, you're expected to use it on a 4k TV no? Just pick up any free-sync display in that budget.
The more expensive ones will be a bit higher quality, just check reviews
https://uk.pcpartpicker.com/products/monitor/#A=2&p=1&r=384002160&sort=price&page=1
Any reason why free-sync?
It might get an update to support it in the future, though that would be free-sync over HDMI...
Otherwise they're just good displays for the price, and it shouldn't cost anymore than displays without free-sync.
 Share
