Search In
  • More options...
Find results that contain...
Find results in...
Low FPS and LOW cpu usage (new pc)
13yrKid
 Share
Okay so ive built my new setup :
CPU- Ryzen 2600
GPU- GTX 1070 amp extreme
mobo - x470 aorus ultra gaming
ram- corsair vangence lpx 3000mghz 2x8gb (it says it supports intel i7 and icore)
psu- corsair cx 650
so, the thing is that i think i have fps problems and in some some games it works fine and in some games the fps is really not acceptable so here are some tests.
Fortnite (epic)
cpu -30%
gpu-90%
fps- 90 to 115
Fortnite (low)
cpu-30%
gpu-55%
fps- 180-200
CSGO (offline low)
cpu-14percent
gpu-18-26
fps-100-150
CSGO(max)
cpu-15
gpu-30-35
fps-100-120
PUBG(low)
cpu-20
gpu-51
fps-100-120
PUBG(max)
cpu-20to30
gpu-97
fps-90to 100
GTAv (max)
cpu-35-40
gpu-80-90
fps- 80-90
GTAV(low)
cpu-34-45
gpu-30-40
fps-100to130
BF4(max)
cpu-37
gpu=97
fps-150to170
BF4(low)
cpu=20-30
gpu- 50
fps-200 stable( not stutter)
BF1(max)
cpu-47to50
gpu-97
fps=80to 100
BF1(low)
cpu-50
fpu-70to80
fps-115to 150
so i hope this info is enough .
the first problem is that the fps in CSGO is significantly low
second problem is- in low settings why is my gpu not used fully.. imean it would make sense if the gpu was at 50 and the cpu was at 80+ but the cpu is also sitting idle .i just want to know if its normal or not, and if its not.. please help me find the bottleneck
this is a new pc and nothing is overclocked yet. i dont want to overclock it yet .. ill be doing that when i get bored of this pc and feel like its not enough.
Thankyou :)
Thankyou :)
The lower the details and resolution, the lower the GPU usage as games become CPU bound. Your CPU has a few pegged cores probably, and that's why the difference between low and high is to small. Overclock your CPU a bit, make sure your RAM is running at 3000 and not 2133. That should bump the FPS up a bit.
That said, if super high FPS is what you're after, you should've bought an i5 or i7 instead. Yes, they cost more, but for just gaming, they're faster.
PC Specs - AMD Ryzen 5 5600X MSI B550M Mortar 16GB Crucial Ballistix DDR4-3600 @ CL15 - RX5700XT 660p 1TBGB & 256GB 600p Fractal Define Mini C CM V550 - Pop!_OS 20.04
ill check the core difference again , and i did not have the budget for i7 :(
thanks for the quick reply.
 Share
