Speed up my 10G connection?
SSD Sean
I got two Aquanta 10GbE NICs off Amazon recently for all that 10GbE goodness. I have multiple NVMe SSDs/RAID arrays in my NAS and desktop. Both feature Windows 10 Pro. I connected both directly to one another via a 15m CAT6 cable. Sending data from a 1TB Samsung 970 EVO in my desktop to an enterprise NVMe SSD in my server I get full 1.15GB/s transfer speed. But transferring from the NAS to the desktop I get like 800MB/s or so to any of my drives, which can write at over 1.2GB/s without an issue when doing transfers locally on the desktop system itself.
Anyone know what settings I need to adjust to fix this? I should be getting 1.15GB/s both ways since storage isn’t the bottleneck, right?
So so far I set RSS to 8 and jumbo frames is set to 9014 or whatever the number is (not home at the moment to double check).
ლ(ಠ益ಠ)ლ
(ノಠ益ಠ)╯︵ /(.□ . \)
What CPU is your n your PC/NAS
Bethesda PC:   R7 3700X  -  Asrock B550 Extreme 4  -  Corsair Dominator Platinum RGB 16GB@3.6GHz -  Zotac AMP Extreme 1080TI -  Samsung 860 Evo 256GB  -  WD Blue 2TB SSD -  500DX  -  Stock cooling lul  -  Rm650x
CrumpleBox V3:  Xeon X5680  -  Asus X58 Sabertooth  -  DDr3 16GB@1.33Ghz  -  Gigabyte 1660s -  TT smart RGB 700W  -
Cooler Master Storm Trooper  -  120GB Samsung 850 Pro   -  LTT Edition Chromax NH-D15 ?
CrumpleBox 3 ROTF: I5-6400  -  MSI B150m Mortar  -  16GB 2133Mhz Vengeance Pro RGB  -  Strix 1070Ti - GTX 1070 FE  -  Adata 128GB SSD  -  Fractal Design Define C  -  Gammaxx 400V2  -  Cooler Master silent pro gold 1000W
CrumpleBox 2: i7-7820x - MSI X299 Raider - 32GB Thermaltake Toughram 3.6Ghz - 2x Sapphire Nitro Fury - 128GB PCie Adata SSD - O11 Dynamic - EVGA CLC 360 - Corsair RM1000X
Perhiperals:  Gateway 900p60 monitor  -  Dell 1024x768@75  -  Logi. G403 Carbon  -  Logi. G502  -  SteSer. Arctis 5  -  SteSer. Rival 110 - Corsair Strafe RGB MK.2
4790k in NAS and E5-2690v3 in desktop.
ლ(ಠ益ಠ)ლ
(ノಠ益ಠ)╯︵ /(.□ . \)
What is your raid setup on each machine? How much ram do you have on each machine? I have a theory, but need more information.
Writing from a NAS to your desktop you will never get theoretical speeds. There is other stuff windows is doing on top of TCP which in it self has a delay which affects your speeds.
So I did some testing and to simplify things well use the following config:
Desktop: X99 + Intel DC P35201.2TB
NAS: Z87 + Toshiba PX04 3.2TB
When writing a 15GB movie from Desktop to NAS or From NAS to Desktop I get a transfer speed of 1.15GB/s.
But, when reading from NAS to Desktop or From Desktop to NAS, I get a transfer speed of 800-900MB/s.
ლ(ಠ益ಠ)ლ
(ノಠ益ಠ)╯︵ /(.□ . \)
From what I can tell you haven't given me any information on your raid setup. I asked because some raid setups prioritize write speed and others read speed. Then you have raid 0 which increases both equally.
I am aware. I have a Microsemi SmartRAID 3154-24i with 8x HGST Ultrastar SS300 SAS 12Gb/s drives in RAID 0 on the Desktop
ლ(ಠ益ಠ)ლ
(ノಠ益ಠ)╯︵ /(.□ . \)
