Will a motherboard post without a CPU and RAM
CALBIX
Go to solution Solved by samcool55,
8 minutes ago, CALBIX said:
So the board will show post numbers?
If it has one of those post code displays, yes it will.
What motherboard do you have?
Hi everyone
A few weeks back my corsair cooler blew inside my case spewing liquid over everything. So I cleaned the motherboard and it worked fine for about 2 days after everything happend but I went to buy myself a new cooler. As soon as I went to install a new cooler and switched my pc back on nothing worked. The motherboard showed that there was power.
After about 3 weeks I would like to test the mobo but I don't want to disassemble my pc just to check.
Thanks
Nope. It'll power on like usual but it will not pass POST without those things installed. Especially without the CPU.
New Build (The Compromise): CPU - i7 9700K @ 5.1Ghz Mobo - ASRock Z390 Taichi | RAM - 16GB G.SKILL TridentZ RGB 3200CL14 @ 3466 14-14-14-30 1T | GPU - ASUS Strix GTX 1080 TI | Cooler - Corsair h100i Pro | SSDs - 500 GB 960 EVO + 500 GB 850 EVO + 1TB MX300 | Case - Coolermaster H500 | PSUEVGA 850 P2 | Monitor - LG 32GK850G-B 144hz 1440p | OSWindows 10 Pro.
Peripherals - Corsair K70 Lux RGB | Corsair Scimitar RGB | Audio-technica ATH M50X + Antlion Modmic 5 |
CPU/GPU history: Athlon 6000+/HD4850 > i7 2600k/GTX 580, R9 390, R9 Fury > i7 7700K/R9 Fury, 1080TI > Ryzen 1700/1080TI > i7 9700K/1080TI.
Other tech: Surface Pro 4 (i5/128GB), Lenovo Ideapad Y510P w/ Kali, OnePlus 6T (8G/128G), PS4 Slim.
So the board will turn on? If the board turns on that's all I need to know
If you want my attention, quote meh! D: or just stick an @samcool55 in your post :3
Spying on everyone to fight against terrorism is like shooting a mosquito with a cannon
Msi z97 Gaming 7
27 minutes ago, CALBIX said:
Msi z97 Gaming 7
only asus boards can go into the bios without cpu and memory. msi can't
1 hour ago, CALBIX said:
Hi everyone
Thanks
The mobo will light up, but will display a post code that signals "no CPU" or "no ram". I have never encountered a motherboard that actually has to have a CPU inserted to recieve power.
Got the Mobo running. Gonna let it run for a few hours just to make sure everything is good before I switch. Thanks for all the help
