Search In
  • More options...
Find results that contain...
Find results in...
liquid cooled Aorus 1080 ti with MSI 1080 ti?
I'm wondering if I can buy these two water blocks for their respective cards and run them SLI.
I have made 1 custom loop before and I have these GPUs laying around, but i have no clue if the tubing lines up.
https://www.ekwb.com/shop/ek-fc1080-gtx-ti-aorus-rgb-nickel
https://www.ekwb.com/shop/ek-fc1080-gtx-ti-tf6-acetal-nickel
thanks for any insight!
6 minutes ago, Schiggy said:
I don't think so... The ports do not line up, and the SLI connector won't line up either. so you won't be able to use a rigid bridge, or a straight connection between the blocks. Of course if you use a flexible bridge and get creative with your loop, anything is possible.
dang. thanks for the help. i guess vega frontier will have to stay as my main gaming card. lol
Don’t see why they have to line up. It’s called custom watercl cooling for a reason.
Main RIg Corsair Air 540, I7 8700k, ASUS ROG Strix Z370-H, G.Skill TridentZ 32GB, EVGA 1080TI SC Black, EVGA 850 GQ, Acer KG251Q 1920x1080@240hz
Spare RIg Corsair Air 540, I7 4770K, Asus Maximus VI Extreme, G.Skill Ares 32Gb, EVGA 1080sc & 1060 SSC, Corsair CX850M, Acer GD235hz 1920x1080@120hz
 Share
