Search In
  • More options...
Find results that contain...
Find results in...
Discussing my Home Storage Plan
 Share
Hello LTT forum!
I'm planning a home storage overhaul at the moment.
Ok here goes
My current plan is to have an external WD MyBook Duo on my computer in RAID 0 for Photo/Video Editing (and all other files), this would then be redundantly synced with the RAID 1 QNAP NAS (8TB but 4TB with RAID 1) for access externally.
Then I would have my system (MyBook + Internal drives - which is all my data) backed up to BackBlaze...
So what'd you think? I'm sure there's some pitfalls of my concept and maybe better solutions that I'm unaware of.
Should I consider having some Cold storage that I backup periodically?
Thanks for your help!
KRONOS:
// AMD FX 8350 // ASUS ROG CROSSHAIR V FORMULA Z // G.Skill Ripjaws 16GB 2x8 1866Mhz DDR3 // ASUS ROG STRIX GTX 1070 OC // CORSAIR SPEC-03 // Kingston SSD v300Now 120GB, 1TB WD Blue // Cooler Master V750 750W // 1x BENQ GL2760H 1080p 60hz 2ms // Corsair H75 CPU Cooler // Razer BlackWidow Ultimate Battlefeild 4 Collectors Edition\K70 RGB Lux Cherry RED // Razer Deathadder Chroma // Logitech G213 Speakers // ASUS ROG MARS GTX 760 X2 (Retired) // Windows 8.1
yes on that.
MSI x399 sli plus  | AMD theardripper 2990wx all core 3ghz lock |Thermaltake flo ring 360 | EVGA 2080, Zotac 2080 |Gskill Ripjaws 128GB 3000 MHz | Corsair RM1200i |100tb | Asus tuff gaming mid tower
 Share
