Search In
  • More options...
Find results that contain...
Find results in...
Threadripper 1950X and 3600Mhz Memory
Kn3xis
 Share
Recently built a threadripper rig for a friend of mine, and all was well. The next day or 2 he was getting a lot of crashing, so we started dropping the various overclocks and settings we changed. After some tinkering we found that his XMP profile for 3600Mhz was causing the crash. Any ideas why?
Aorus X399 Extreme
Corsair Vengeance RGB 32GB 3600Mhz
The 1950X's integrated memory controller is not the greatest with high speed memory. My 2950X handled quad channel 3600 fairly easily. Not the same story w/ the 1950X and the same kit.
21 minutes ago, Kn3xis said:
3600mhz is likely way too high
Just set the XMP profile, put the voltage to 1.4V for the memory only, then drop the speed to like 3000-3200mhz
 Share
