Search In
  • More options...
Find results that contain...
Find results in...
Harddrive Need Help To Fix It
KeyzHostHD
 Share
hi iv taken my moms external harddrive and want to fix it for her it has many family photos , documents. it powers on the led indicating its on.
ok so it's never been formated or dropped nothing spilled on it either
when I connect it I hear the Windows sound to indicate it's connected.  when I put my ear close to it I hear a trr trr trr sound. it doesn't show up in file explorer . but it occasionally poops up in
disk management for 2 seconds
after it's on it is spinning without a sound
how can I recover the most data as possible. maybe force it to show up and scan the sectors?  what programs
go to disk management and assign a drive letter on the partition.
Ryzen 3600 @ 4.5ghz all cores | Asrock B550M Steel Legend | Radeon RX580 | 2x Samsung 16gb c-die 2666 @ 3600mhz cl16 | 500gb WD SN750 | 9 TB HDD | Deepcool Gammax 400 w/ 2 delta 4000rpm push pull | Antec Neo Eco Zen 500w
problem is it poops up but disappears after 2 second no time to do so
If the drive sounds like it is clicking or you have seen s.m.a.r.t disk errors you risk losing data just by using the disk or trying anything and you should consult a professional such as Drive Savers who Linus reviews in this Video.  If you don't think the drive is physically failing but only the interface and controller of the external enclosure, you can simply take the drive out of the external and plug it into your internal sata, or use an external dock or interface such as this
Thermaltake Blacx Duet
or this
Sabrent USB 3.0 to SATA
There are much cheaper ones but those are ones I would recommend for quality in a critical scenario.
or this
ok I will try to find one close to me as I live in norway
 Share
