Search In
  • More options...
Find results that contain...
Find results in...
Overclocked Monitor, Games stuck at 60hz
SonicThunder
 Share
Windows and Nvidia are both set to 75hz, but every game menu, I.e. Gta V, BO4, only go up to 60hz, what gives.
Weak hardware, can't always do higher refresh rates. Also go into the settings of games they often have fps limiters.
I'm using games that used to let me set them to 75hz before I moved them to a new hard drive.
Probably a game update, but you can set it to unlimited fps usually.
I'm specifically talking Black ops 4 and GTA V, I can set the FPS to uncapped, but the refresh rate is stuck at 60
 Share
