Front Panel Connectors
Solved by brob,
Sadly, I could not find any details in the H310M-K User Manual.
Some Asus motherboards include a labeled plastic block to which the case front panel leads connect. The block then plugs into the motherboard front panel header. If memory serves this is called a quick connect. If not present, see the link in Best Answer of http://www.tomshardware.com/answers/id-3750348/asus-prime-h310m-front-panel-connectors.html.
