Search In
  • More options...
Find results that contain...
Find results in...
pcpartpicker shows an error
  • Some AMD B350 chipset motherboards may need a BIOS update prior to using Pinnacle Ridge CPUs. Upgrading the BIOS may require a different CPU that is supported by older BIOS revisions.
Will PRIME B350M-A motherboard work out of the box with Ryzen 5 2600 without needing any bios updates needed.
Motherboard: https://www.amazon.co.uk/gp/product/B06WWF12J8/ref=ox_sc_act_title_4?smid=A3P5ROKL5A1OLE&psc=1
Ryzen cpu: https://www.amazon.co.uk/gp/product/B079D8FD28/ref=ox_sc_act_title_2?smid=AFXON1SGSPLH4&psc=1
Other system specs:
Power Supply: https://www.amazon.co.uk/gp/product/B01C3FFOHS/ref=ox_sc_act_title_3?smid=A3P5ROKL5A1OLE&psc=1
RAM: https://www.amazon.co.uk/gp/product/B01ARHBBPS/ref=ox_sc_act_title_7?smid=A3P5ROKL5A1OLE&psc=1
Thank you to all that reply :3
No way knowing if the retailer doesn't say any thing.
Personal Desktop":
CPU: Intel Core i7 8700 @4.45ghz |~| Cooling: Cooler Master Hyper 212X |~| MOBO: Gigabyte Z370M D3H mATX|~| RAM: 16gb DDR4 3333mhzCL16 G.Skill Trident Z |~| GPU: nVidia Founders Edition GTX 1080 Ti |~| PSU: Corsair TX650M 80Plus Gold |~| Boot:  SSD WD Green M.2 2280 240GB |~| Storage: 1x3TB HDD 7200rpm Seagate Barracuda + SanDisk Ultra 3D 1TB |~| Case: Fractal Design Meshify C Mini |~| Display: Toshiba UL7A 4K/60hz |~| OS: Windows 10 Pro.
Luna, the temporary Desktop:
CPU: Intel Core i7 10700KF @ 5.0Ghz (5.1Ghz 4-core) |~| Cooling: bq! Dark Rock 4 Pro |~| MOBO: Gigabyte Z490 UD |~| RAM: 32G Kingston HyperX @ 2666Mhz CL13 |~| GPU: AMD Radeon RX 6800 (Reference) |~| PSU: Corsair HX1000 80+ Platinum |~| Windows Boot Drive: 2x 512GB (1TB total) Plextor SATA SSD (RAID0 volume) |~| Linux Boot Drive: 500GB Kingston A2000 |~| Storage: 4TB WD Black HDD |~| Case: Cooler Master Silencio S600 |~| Display 1 (leftmost): Eizo (unknown model) 1920x1080 IPS @ 60Hz|~| Display 2 (center): BenQ ZOWIE XL2540 1920x1080 TN @ 240Hz |~| Display 3 (rightmost): Wacom Cintiq Pro 24 3840x2160 IPS @ 60Hz 10-bit |~| OS: Windows 10 Pro (games / art) + Linux (distro: NixOS; programming and daily driver)
As, the princess said, that would be a question for the place you buy it from. If they don't know, assume the worst and get the AMD update kit.
Other system specs:
Just buy a b450 motherboard if you don't want to worry about the motherboard not having the required bios for the 2600. The b450 will be compatible 100% of the time and will work out of the box.
Other system specs:
https://www.amazon.co.uk/ASUS-PRIME-B450-PLUS-Socket-Motherboard/dp/B07F6ZXNXK/ref=mp_s_a_1_8?ie=UTF8&qid=1543953794&sr=8-8&pi=AC_SX236_SY340_FMwebp_QL65&keywords=b450+motherboard&dpPl=1&dpID=51M9aTE-krL&ref=plSrch just get this instead.
 Share
