Has PC tech become stagnant? I think so.
I would argue a lot of the apparent stagnation is simply because what we as consumers do with computers don't require a lot of power to reach acceptable levels of performance and quality. Especially when a lot of things moved to the web and we have phones to access the content, developers have to design things with even lower performance requirements in mind. Since we have apps and software that are meant to perform well on lower power devices, it makes sense that putting them on higher end hardware won't improve the apparent performance.
I'm sure a lot of people here haven't experienced the joys of actually worrying about if their PC will play an MP3 or not. Or that a 1 minute uncompressed WAV file (that wasn't even CD quality!) would eat all your RAM if you tried to work with it.
Also I would argue a vast majority of the performance boost from the 90s came simply from adding more speed. For example, the OG Pentium launched with a 60 MHz model. Two years later it had a 120 MHz model. Within 7 years in that time frame as well, we went from 60 MHz to 1GHz, a 16 fold increase. And while sure there were architecture improvements that helped, I'm not sure if those played a significant role in boosting general performance overall moreso than the clock speed bump. The speed bump from an i7-2600K to an i7-8700K assuming max turbo boost? 1.26x increase.
