Search In
  • More options...
Find results that contain...
Find results in...
i have two speakers 115 w RMS and 3 ohm
danielyacov
 Share
That thing is not even close to 200W RMS. It's 24W max because that's the max power it can draw from whatever the power source is.
It's good enough for some cheap simple speakers, but nothing more than that.
If you want my attention, quote meh! D: or just stick an @samcool55 in your post :3
Spying on everyone to fight against terrorism is like shooting a mosquito with a cannon
so what should buy?
Just now, danielyacov said:
so what should buy?
Depends what speakers you have.
Maybe give us the model number of what you want to power.
9 minutes ago, danielyacov said:
It needs 115 max, i guess something that can do 60-80w RMS should be plenty.
But that's as far as my knowledge goes, i don't know what i should recommend because i'm not experienced enough ?
ok thank you
why dont you just get a cheap 100 to 150 watt stereo receiver? why are you looking at car like amps? like the one you posted theres no way a plug in adapter like it takes can give you the power needed to push watts like that.
you can recommend me?
what would be your price range? theres used/refurbs as low as 49 dollars.....new around 119.00 and these are name brand not pyle brand type junk
up to 50...
49.99 denon
the only thing in your price range for a used/refurb
i mean all in all maybe check facebook store, or craigslist. or just save up and buy a new set up later
 Share
