Cable sticking out next to PCI
Dzak
Hello,
I just received my graphic card and there is a cable sticking out next to PCI. Would it be safe to use the card with it there? Can I just push it back? Thank you.
Regards,
Dzak
Looks like someone has had the cooler off of that card at some point and pinched the fan wires in there.
Just carefully push them aside and you should be fine.
Probably fan leads from the cooler. Just push them back in so they're not under any sort of mechanical stress.
Main PC:
AMD Ryzen 7 5800X • Noctua NH-D15 • MSI MAG B550 Tomahawk • 2x8GB G.skill Trident Z Neo 3600MHz CL16 • MSI VENTUS 3X GeForce RTX 3070 OC • Samsung 970 Evo 1TB • Samsung 860 Evo 1TB • Cosair iCUE 465X RGB • Corsair RMx 750W (White)
Peripherals/Other:
ASUS VG27AQ • G PRO K/DA • G502 Hero K/DA • G733 K/DA • G840 K/DA • Oculus Quest 2 • Nintendo Switch (Rev. 2)
Laptop (Dell XPS 13):
Intel Core i7-1195G7 • Intel Iris Xe Graphics • 16GB LPDDR4x 4267MHz • 512GB M.2 PCIe NVMe SSD • 13.4" OLED 3.5K InfinityEdge Display (3456x2160, 400nit, touch).
Got any questions about my system or peripherals? Feel free to tag me (@bellabichon) and I'll be happy to give you my two cents.
PSA: Posting a PCPartPicker list with no explanation isn't helpful for first-time builders :)
Thanks guys for the replies.
The card is supposed to be brand new, since someone took the fan out, do you think it would be worth to replace it for new one or just keep this one?
