Search In
  • More options...
Find results that contain...
Find results in...
RGB case fans with B450M-DS3H ?
RyzenPower
 Share
Go to solution Solved by AirSocial,
Just now, RyzenPower said:
Ok, so instead of connecting to the rgb controller i put 1 to 3 rgb splitter to the RGB LED strip header and keep the controller aside? and what is the use of this system fan header, what to connect with that?
Your fans should have two cables. Look at the manual and see which one is for RGB and the actual fan. Plug the fan into your board in the system fan header and plug the rgb plug into the spliier. Then plug the spliter into your mobo.
I am using Gigabyte B450m-ds3h motherboard and Cooler master masterbox mb500 cabinet. This case comes with three rgb fans preinstalled. It also has rgb controller. But i want to control fan color and color style via gigabyte rgb fusion app. The motherboard has 1 x cpu cooler LED strip/RGB LED strip header(4 pin). The motherboard also has 1 x system fan header(4 pin). Can i use rgb fusion with this motherboard to control my fans' rgb?
I have attached motherboard manual, if anyone would like to take a look. Thank you.
Note: Please check the motherboard manual and the case product sheet ( i've attached).
Product_Sheet_-_MasterBox_MB500.pdf
mb_manual_b450m-ds3h_e.pdf
Just plug the RGB cable from the controller to the RGB header on the motherboard, then plug the fans' RGB connector to the controller and test the RGB software. No need to read manuals or anything when you can already try
Model: HP Omen 17 17-an110ca CPU: i7-8750H (0.125V core & cache, 50mV SA undervolt) GPU: GTX 1060 6GB Mobile (+80/+450, 1650MHz~1750MHz 0.78V~0.85V) RAM: 8+8GB DDR4-2400 18-17-17-39 2T Storage: 1TB HP EX920 PCIe x4 M.2 SSD + 1TB Seagate 7200RPM 2.5" HDD (ST1000LM049-2GH172), 128GB Toshiba PCIe x2 M.2 SSD (KBG30ZMV128G) gone cooking externally Monitor: 1080p 126Hz IPS G-sync
Desktop benching:
I don't want to damage anything accidentally. Because i am not sure if RGB led strip header is same thing as RGB header? It would really help if you read these one page manuals.
I have used both of these separately.  RGB header is fine to use for the fans from the case.  What you need is a splitter cooler master sells: https://www.amazon.com/Cooler-Master-Splitter-Compatibility-Radiators/dp/B0719QY63M it will take 3 RGB Cables into 1 for your header connection.
you wont damage anything. they physically don't fit into the wrong ports.
Desktop benching:
Can you check the one page product sheet pdf of the case i have attached please? It says it is providing 1 to 3 rgb splitter. Is it the same thing you are talking about or do i need another one?
Still i am kind of afraid. Just read those one page pdf please, i have zero experience on these, would appreciate. I have attached both pc case and motherboard pdf file.
You will be fine
Main PC
i5-9400f @2.9GHz | Corsair H100i Elite Capellix |Gigabyte RGB GTX1060 6GB | Corsair CX650M | Island Professional 120GB SSD | Toshiba 2TB HDD | Corsair Vengeance RGB Pro 2x16 DDR4 3200MHz  | Corsair iCUE 220T | Windows 10 Pro | CPU R20 Cinebench Score -  pts | OpenGL FPS -  FPS | Novabench Score (OC) -  Base -
Keyboard and Mouse
Corsair K70 RGB MK.2 Cherry Mx Red | Corsair Glaive RGB
Streaming PC (HP Compaq 8100 SFF)
Xeon X3440 @2.53GHz | Radeon HD 6450 | HP Compaq 240watt PSU | Toshiba 1TB HDD | Samsung 2x4 DDR3 1333MHz | HP Compaq 8100 SFF | Windows 10 Pro | CPU Cinebench Score - 409 cb | OpenGL FPS - 16.77 FPS | Novabench Score (OC) - 991 Base - 938
Keyboard and Mouse
Logitech G413 Silver White LED Romer-G Switch | Old Gateway Mouse
Monitors
AOC - 21.5" IPS LED FHD Model - l2279VWHE | AOC - 24" TN Panel FHD 144hz 1ms Response - Model G2460PF
2 minutes ago, AirSocial said:
You will be fine
Hi, did you check those two manuals i have attached at my first post? Please check and tell me what you think ?
I dont have to go though the manuals. You asked for help and Im telling you. If you wanna check then you can read through the manuals. I know it will work.
Main PC
Keyboard and Mouse
Keyboard and Mouse
Monitors
I just saw and you have been on this same problem for over 12 hours, By now you could have read through the manual and learned. Everyone starts somewhere.
Main PC
Keyboard and Mouse
Keyboard and Mouse
Monitors
Main PC
Keyboard and Mouse
Keyboard and Mouse
Monitors
Yeah thanks for you time and help, you can move on now.
Did you build this system or bought it
Main PC
Keyboard and Mouse
Keyboard and Mouse
Monitors
 Share
