Search In
  • More options...
Find results that contain...
Find results in...
Cables for the following build:
R U CRAZY
 Share
Go to solution Solved by CableMod,
@R U CRAZY we have premade kits that are aggressively priced, all of these would have what you need for this setup.
https://store.cablemod.com/products/?filter_models=rmi-rmx
Otherwise if you want to check out our configurator and do further customization, you would need the following:
1x 24-pin ATX (Motherboard power)
1x 8-pin EPS (CPU power)
1x 4-pin EPS (CPU power)
1x 8-pin PCI-E (Graphics/GPU power)
1x 6-pin PCI-E (Graphics/GPU power)
If the Crucial is the 2.5" variant, 1x SATA Power / 1x SATA Data (optional).
Boring talk:
Hello guys, I have already uploaded a post here regarding my PC build, I have made some changes due to budget issues, but anyway, I'm planning on getting custom sleeved cables of my build, because after buying everything in Black Friday, I realized that I still had some money from my budget left, and I always wanted sleeved cables, now's my chance, so this is my build:
Actual stuff:
CPU: Ryzen 7 2700X
GPU: Zotac AMP! RTX 2080
Mobo: AsRock TaiChi X470
RAM: TridentZ RGB
Main Storage: Samsung 970 Evo
Secondary storage: Crucial MX500
CPU cooler: Corsair h115i Pro RGB
Case fans: be quiet! Silentwings 3 120mm PWM
PSU: Corsair HX850 Platinum
Case (if it matters): Lian Li PC-O11 Dynamic
What cables do I need for this build? (All cables preferably, but as much as you know)
Thanks in advance!
Wow, thanks.
 Share
