Corsair Graphite 780T radiator top mounting?
Troika
The booklet says it can mount two 360mm rads on the top, according to point B on case features on page 4 of the downloadable pdf. Can anyone confirm this and how they're actually mounted? I haven't bought the case in question but if it can do two 360mm rads on the top, I may seriously consider getting it.
The website says it can do two 360mm rads, not two on top. If it could, that would be an insanely wide case. It can support a 360mm radiator on top and probably a 360 in the front also.
My Build, v2.1 --- CPU: i7-8700K @ 5.2GHz/1.288v || MoBo: Asus ROG STRIX Z390-E Gaming || RAM: 4x4GB G.SKILL Ripjaws 4 2666 14-14-14-33 || Cooler: Custom Loop || GPU: EVGA GTX 1080 Ti SC Black, on water || PSU: EVGA G2 850W || Case: Corsair 450D || SSD: 850 Evo 250GB, Intel 660p 2TB || Storage: WD Blue 2TB || G502 & Glorious PCGR Fully Custom 80% Keyboard || MX34VQ, PG278Q, PB278Q
Audio --- Headphones: Massdrop x Sennheiser HD 6XX || Amp: Schiit Audio Magni 3 || DAC: Schiit Audio Modi 3 || Mic: Blue Yeti
[Under Construction]
My Truck --- 2002 F-350 7.3 Powerstroke || 6-speed
My Car --- 2006 Mustang GT || 5-speed || BBK LTs, O/R X, MBRP Cat-back || BBK Lowering Springs, LCAs || 2007 GT500 wheels w/ 245s/285s
The Experiment --- CPU: i5-3570K @ 4.0 GHz || MoBo: Asus P8Z77-V LK || RAM: 16GB Corsair 1600 4x4 || Cooler: CM Hyper 212 Evo || GPUs: Asus GTX 750 Ti, || PSU: Corsair TX750M Gold || Case: Thermaltake Core G21 TG || SSD: 840 Pro 128GB || HDD: Seagate Barracuda 2TB
R.I.P. Asus X99-A motherboard, April 2016 - October 2018, may you rest in peace. 5820K, if I ever buy you a new board, it'll be a good one.
Oooh, you're right. I didn't notice the other B at the front of the case xD
That's still pretty good though, I assume you'd lose the 5.25" bays at the front.
Possibly, it’s a bigger case though so maybe not. Even so... do you use an optical drive?
Yes but I planned on ditching the optical drive for a dual 5.25" bay res for a custom loop at some point. It should still be fine cooling wise. A big 360mm at the top, a 280 at the front, a 240mm at the bottom and a 140mm at the back. Should be plenty.
