cpu cooler Recommended cooler for Ryzen 7 2700x
3 minutes ago, NuKeCoDeS said:Ok thanks for the tips. If I stick with the stock cooler, sound wise, how loud can it get and would it make a big difference if I get the Noctua?
I mean, the stock cooler WILL have noise, but it's not like it's going to too loud. Especially if you use a headset or have audio going on. The only time you'll really notice it is during heavy processing and in a semi-quiet room. Other than that it's nothing to worry about. Plus, since it comes with the processor, you can just stick to the stock cooler and if it bugs you that much then you can buy a different one.
The Notcua is just hands down the quietest out there and offers amazing cooling. So if you see that you don't like the noise levels and temps on the stock then pull the trigger on something like the Dark Rock 4 or the Noctua.
