Search In
  • More options...
Find results that contain...
Find results in...
Need advice on building pc
Hi there, Im planning on building a pc but I am not sure of wich processor use,
I’m between the i5-8600k and the i7-7700k  that will go with a gtx 1050ti
The main purpose is to have a workstation and play some games once in a while.
Ive read that everybody prefers the 8600k but they only focus on gaming and no as a workstation.
I need it to nicely run programs like autodesk Revit, Lumion, photoshop at the same time.
About the games I’d like to run decently PUBG, dota 2, cs go with no overclocking in mind.
thanks in advance
The 2 physical cores have an advantage over the 4 hyperthreads of the 7700k, but as @LukeSavenije said, a ryzen 5 2600 is even better, and cheaper.
Primary PC:
i7 8086k (won) - EVGA Z370 Classified K - G.Skill Trident Z RGB - WD SN750 - Jedi Order Titan Xp - Hyper 212 Black (with RGB Riing flair) - EVGA G3 650W - dual booting Windows 10 and Linux - Black and green theme, Razer brainwashed me.
Linux Proliant ML150 G6:
Dual Xeon X5560 - 24GB ECC DDR3 - GTX 750 TI - old Seagate 1.5TB HDD - dark mode Ubuntu (and Win7, cuz why not)
How many watts do I need? Seasonic Focus thread, PSU misconceptions, protections explainedgroup reg is bad
If you need Intel, 8600K. I'd take the extra cores over hyperthreading. Clock speed is basically the same on both.
REMEMBER:
IF YOU WANT ME TO RESPOND, YOU GOTTA QUOTE ME
OR
PUT @Fixinit1 IN YOUR RESPONSE!!!!!
Gosh, I hate it when people forget. Anyway, check out my PC below, and there's a PCPartPicker link on my profile, If you wanna see what I'm planning.
SYSTEM SPECS: Finally ditched the Pentium N3540, now I've got the following:
CPU - Ryzen 5 2400G
GPU - 1060 6GB Gigabyte G1 Gaming
RAM - 16GB DDR4 3000mhz Team T-Force Delta RGB
MOTHERBOARD - MSI B350 Tomahawk
PSU - EVGA 450BT
CASE - PHANTEKS  P350X
i7-8700.
Model: HP Omen 17 17-an110ca CPU: i7-8750H (0.125V core & cache, 50mV SA undervolt) GPU: GTX 1060 6GB Mobile (+80/+450, 1650MHz~1750MHz 0.78V~0.85V) RAM: 8+8GB DDR4-2400 18-17-17-39 2T Storage: 1TB HP EX920 PCIe x4 M.2 SSD + 1TB Seagate 7200RPM 2.5" HDD (ST1000LM049-2GH172), 128GB Toshiba PCIe x2 M.2 SSD (KBG30ZMV128G) gone cooking externally Monitor: 1080p 126Hz IPS G-sync
Desktop benching:
18 hours ago, Jurrunio said:
i7-8700.
I just searched what was the difference withh the ‘k’ in the processor, i think the 8700 may be a good option, thank you
 Share
