How to speed up win 7?
iKratos
Hi, recently I switched from Win 10 to Win 7 and win 10 is a bit fast compared to win 7 but is a complete bloatware whereas win 7 is perfectly stable.
Now, I am experiencing some slowness when I m copying files and some other things. So, how do I speed such things up? Is there any way to make it fast like Win 10?
1 minute ago, M.Yurizaki said:
Explain this "slowness", because this sounds really vague.
Copying files from one partition to another. Opening any windows.
1 minute ago, Brooksie359 said:
Get a nice ssd to install it on.
I already have it.
You can turn off the "bloatware" anyway.
It won't be bloated if you're pc is up to it.
Win 7 is really old, i only used it if the memory is really low.
like 512mb in core 2 duos.
I already have it.
copying files from another partition on the same disk will be slow. even on high end pc.
defrag your hdd, it may help a little.
What are your specs? This 'slowness' you are taking about could just be from lack of power.
Main PC:
AMD Ryzen 7 5800X • Noctua NH-D15 • MSI MAG B550 Tomahawk • 2x8GB G.skill Trident Z Neo 3600MHz CL16 • MSI VENTUS 3X GeForce RTX 3070 OC • Samsung 970 Evo 1TB • Samsung 860 Evo 1TB • Cosair iCUE 465X RGB • Corsair RMx 750W (White)
Peripherals/Other:
ASUS VG27AQ • G PRO K/DA • G502 Hero K/DA • G733 K/DA • G840 K/DA • Oculus Quest 2 • Nintendo Switch (Rev. 2)
Laptop (Dell XPS 13):
Intel Core i7-1195G7 • Intel Iris Xe Graphics • 16GB LPDDR4x 4267MHz • 512GB M.2 PCIe NVMe SSD • 13.4" OLED 3.5K InfinityEdge Display (3456x2160, 400nit, touch).
Got any questions about my system or peripherals? Feel free to tag me (@bellabichon) and I'll be happy to give you my two cents.
PSA: Posting a PCPartPicker list with no explanation isn't helpful for first-time builders :)
I already have it.
Get an nicer ssd ?
oc it :P
go to win10 and uninstall/deactivate bloatware
 Its really good and it works on WIndows 8.1 and 10 too.
Edited by josbeph83
I didnt make it
PC: Ryzen 7 2700 | RX 5700 XT | Asus Prime B450-PLUS | CoolerMaster Masterwatt 600W | 32GB Corsair Vengeance 3200MHz RAM | 512GB NVME SSD & 7TB combined HDD | macOS Monterey 12.6.6, Windows 7 Ultimate x64 and WIndows 10 Pro x64
Laptop: MacBook Pro 15" 2015 | i7-4870HQ | R9 M370X | 16gb | 1tb SSD
iPhone 13 Pro Max | 256GB | iOS 15.7
My Folding Stats | #MuricaParrotGang
So I can turn off every bloatware and completely remove telemetry in Win 10? I searched about and there are lots of tutorials and I got confused. Do you any working guide to COMPLETELY and remove all those bloatwares too?
Alright.
i7 3632qm, 8 gb ram, 4gb nvidia 750m, 250 gb samsung ssd.
7 minutes ago, Brooksie359 said:
Get an nicer ssd ?
I am already using samsung 250 gb ssd. :3
6 minutes ago, Happycowdance said:
oc it :P
Are you sure I can turn off every bloatware and completely remove telemetry in Win 10?
4 minutes ago, M.Yurizaki said:
And you're certain the storage has no glaring issues like benchmarks reporting performance that's not normal for it or SMART data is not reporting something bad?
Wow. That is highly in-depth technical. :P
Thanks for the link mate.
Get a program called HDD Sentinel run it, it can measure the health of the disk also if any error it has.
After that scan the drive for sector damage.
Damaged hdd can also contribute to slowness or worse crashing.
Alright.
Is it a 970 pro?
Tagging @iKratos because this information is more important to them than me
On it, thanks mate. :)
37 minutes ago, Brooksie359 said:
Is it a 970 pro?
Lenovo y500.
No problem ??
