Search In
  • More options...
Find results that contain...
Find results in...
Displayport to VGA Adapter problem
Dean0919
 Share
I have this problem: My monitor is connected to my PC with display port cable, which was working fine. Today I decided to swap my monitor to my wife's monitor. So I tried to connect my monitor which has only HDMI, Display port and DVI ports to her computer which unfortunately has only VGA port, so for that I bought this Displayport to VGA Adapter & tried to make it work, but monitor gave me message: "check cable connection". I tried everything, turned off, turned on, but didn't work, so then I took my monitor back and tried to connect it with Display port cable like I used to, but boom! It gives me same message. I don't know what to think now. Did that adapter damaged my display port cable at all? Or did my monitor's display port port got damaged by that cable now? Or I don't know what to think. I'm super upset. Not only I wasted 15$ for that useless adapter, but now can't even use display port anymore and now I'm using HDMI cable. I don't know if it's related but on the package of that adapter it says: "supports up to 1080p resolution". My monitor has 2560x1080p resolution. What are your thoughts?
CPU: Intel® Core™ i5-10400F | COOLER: Arctic Freezer 34 eSports | MOTHERBOARD: Gigabyte B460M DS3H | RAM: Viper Steel Series 32GB | GPU: Gigabyte GTX 1070 G1 Gaming 8GB | STORAGE: Kingston 240GB SA400M8 SSD + 2TB HDD + 4TB HDD | CASE: Cooler Master HAF 912 Plus | PSU: XFX PRO1050W Black Edition (80+ Gold) | KEYBOARD: Corsair Vengeance K70 | MOUSE: Logitech G502 | MOUSEPAD: Marvo MG010 | MONITOR: Dell S2721D 27" | SPEAKERS: Microlab Solo7C | HEADSET: Trust GXT 410 Rune Illuminated | WEBCAM: Fifine 1440P | OS: Windows 10 64bit
so you went back and it still isnt working with how you had it before? did you try a VGA to DP adapter where the VGA port is directly on the pc, has a short run or no run to the DP port, and then run the dp to your monitor? or did you run a long VGA cable and then plug the adapter directly into your monitor?
Rig 1: i7-9700k OC'd to 5.0ghz all core | EVGA XC RTX 2080Ti | ADATA DDR4 2400mhz 4x8gb | ASUS PRIME Z370-P | Asetek 550LC 120mm | ADATA 480GB SSD & Toshiba P300 3TB | Cooler Master Masterbox MB500 | Win 10 Home | Logitech G910 Orion Spectrum, G502 Proteus Spectrum, G933 Artemis Spectrum Snow Wireless Limited Edition, Corsair MM300 Mouse Pad | 2 MSI Optix Curved 27" FHD Monitors
(before i sold the WD drive and MSI gpu - https://www.userbenchmark.com/UserRun/11946219 171 gaming. felt good.)
Rig 2: i7-7700k Stock clocks | MSI Armor GTX 1070 | ADATA DDR4 2400mhz 2x8GB | MSI Z270 A-Pro | WD Green 240GB SSD & 2TB Seagate HDD | Thermaltake Core G21 Tempered Glass Edition | Win 10 Home | 2 HP Omen FHD 144hz 24.5" Monitors
Rig 3: i7-6700 | GT 730 & GT 645 OEM | Some random DDR4 2133mhz 2x8gb sticks | OEM Dell Mobo | WD Black 2TB HDD & Toshiba 1TB HDD | Win 10 Home | 3 27" Dell FHD Monitors
Rig 4: i7-4770 | EVGA SSC 1050ti | Some random DDR3 ram 2x2gb and 2x4gb sticks | OEM Dell Mobo | Stock Cooler | 1TB WD Black HDD | Win 7 Home
RIP
Rig 5 (dead and dismantled and sold) : i7-7820X OC'd to 4.8ghz all core | MSI DUKE 1080ti | ADATA DDR4 2400mhz 4x8gb | Gigabyte X299 UD4 PRO | Asetek 240mm AIO | WD Green 240gb SSD | Other various components that I can't remember
Rig 6 (same fate as rig 5) i7-8700k stock clocks | MSI DUKE 1080ti | ADATA DDR4 2400mhz 2x8gb | MSI Z370 A-Pro | Asetek 550LC 120mm | WD Green 240GB SSD & Toshiba 2TB HDD | Other various components that I can't Remember
porting from vga to dp is a) not a good idea and b) adapters work only in the direction dp -> vga (dp on the pc, vga on the monitor)
GUITAR BUILD LOG FROM SCRATCH OUT OF APPLEWOOD
- Ryzen Build -
R5 3600 | MSI X470 Gaming Plus MAX | 16GB CL16 3200MHz Corsair LPX | Dark Rock 4
MSI 2060 Super Gaming X
1TB Intel 660p | 250GB Kingston A2000 | 1TB Seagate Barracuda | 2TB WD Blue
be quiet! Silent Base 601 | be quiet! Straight Power 550W CM
2x Dell UP2516D
- First System (Retired) -
Intel Xeon 1231v3 | 16GB Crucial Ballistix Sport Dual Channel | Gigabyte H97 D3H | Gigabyte GTX 970 Gaming G1 | 525 GB Crucial MX 300 | 1 TB + 2 TB Seagate HDD
be quiet! 500W Straight Power E10 CM | be quiet! Silent Base 800 with stock fans | be quiet! Dark Rock Advanced C1 | 2x Dell UP2516D
Reviews: be quiet! Silent Base 800 | MSI GTX 950 OC
that's what I thought, but wasn't sure so voiced my opinions to get more of a solid explanation. HOWEVER, i dont understand why it wont work after OP brought it back to the original configuration.
RIP
Then, I don't understand why they sell such things if they don't work that way & I paid 15 bucks for it. Also why my cable isn't working anymore.
It says DP to VGA not the other way around.
DP is digital signal, VGA is analog.
It needs a special chip to convert the signal.
So the converter has to convert the digital signal to analog, not the other way around.
Maybe you will need an analog to digital converter to output the vga port.
Ryzen 3600 @ 4.5ghz all cores | Asrock B550M Steel Legend | Radeon RX580 | 2x Samsung 16gb c-die 2666 @ 3600mhz cl16 | 500gb WD SN750 | 9 TB HDD | Deepcool Gammax 400 w/ 2 delta 4000rpm push pull | Antec Neo Eco Zen 500w
Exactly. it's not working anymore. I put this adapter on VGA cable which is connected on my wife's PC, then I put it in my monitor, in display port port and it doesn't give me signal. Then I went back to my PC with display port cable and it's still not giving me signal anymore. Could this adapter damage this cable?
i doubt that it could damage it... but its not out of the realm of possibility. can you try every display port on your GPU? (or mobo if you integrated)
RIP
So you're saying if I would put that adapter in cable, display port should be connected in my PC and vga part into monitor? And when I did in opposite, that's why it didn't work? Could it damage cable?
Yes, I tried and non of them gives signal.
i honestly have no clue then... does the monitor have multiple DP ports?
RIP
No, only one.
i really don't know what else to do then... i never have heard of it killing a port by using an adapter
RIP
Yeah DP part to the pc the vga part to the monitor.
This controller solved the problem of people who has no vga port but still wanted to use their old vga only monitor.
To damage the monitor i don't think it can do that, but i don't know, as you are reversing the electrical current.
For $15 you may have more luck with used cheap pci-e cards.
Or you can use USB GPU like this one:
I think it killed my display port cable. Tomorrow will try to test this cable with others.
Well I tested the cable and it seems working. Our IT guy gave me new display port cable to test my monitor, I tested, plugged it in monitor and it still says "check cable connection". Seems like that adapter damaged my monitor's display port port :(
Well, good thing is I still can use my monitor just with HDMI instead of display port.
As mentioned, most adapters only work in one direction. "DisplayPort to VGA" is for a DP source to a VGA display. You would need a VGA to DisplayPort adapter, which I'm not sure even exists, since demand would be very low.
I doubt plugging in an adapter the wrong way would damage the monitor. Try unplugging the monitor from power for a minute, that forces a hard reset and sometimes doing that will help.
I unplugged it for whole night and still it's same, can't make it work anymore.
 Share
