Search In
  • More options...
Find results that contain...
Find results in...
Will ASRock B450 PRO4 support AX4U320038G16-DRS with ryzen 5 1600 ?
I have an asrock b450 pro4 and a ryzen 5 1600. I have tested corsair 3000 mhz , crucial 2400 mhz , and some other 2133 rams but none of them are stable. Some of them didn't even post. Is it because of my processor being 1st gen ryzen and mobo being 2ng gen ? I'm thinking of buying Adata xpg spectrix d40 (AX4U320038G16-DRS) . Will it support my build ? Will it be able to run stable at 3200 with my hardwares? Will my processor be able to support this ram with 3200mhz with my motherboard? I'm so screwed. Please Help!
maybe something else is going on, not just memory. While 1st gen Ryzen has poor memory compatibility from the start, even then DDR4-2133 works. Just no overclocking.
Model: HP Omen 17 17-an110ca CPU: i7-8750H (0.125V core & cache, 50mV SA undervolt) GPU: GTX 1060 6GB Mobile (+80/+450, 1650MHz~1750MHz 0.78V~0.85V) RAM: 8+8GB DDR4-2400 18-17-17-39 2T Storage: 1TB HP EX920 PCIe x4 M.2 SSD + 1TB Seagate 7200RPM 2.5" HDD (ST1000LM049-2GH172), 128GB Toshiba PCIe x2 M.2 SSD (KBG30ZMV128G) gone cooking externally Monitor: 1080p 126Hz IPS G-sync
Desktop benching:
^^^ Ran my R5 1600 just fine on a B450-F, are you sure you're on the latest BIOS?
Current Rig - i7 6950X - EVGA X99 Classified - 4x8GB 3200Mhz CL16 DDR4 - 2060 Super FE - 1TB 970 Evo + 500GB WD Blue SSD + 1TB MX500 - LG WH14NS40 BluRay Drive - EVGA 1000W G3 - Corsair Air 540 - Noctua iPPC NF-A14 3000 (rear) + 3x Noctua NF-P12 redux-1700 PWM (radiator) - LG 27UK650-W (27" 4K60hz) - Custom CPU/GPU Loop w/single 360mm rad - Windows 10
Project Rig (WIP) - Xeon I forgot the name of - NH-L12S - EVGA X99 Micro 2 - 4x4GB 2800MHz DDR4 - WX2100 2GB - 256GB 960 Evo - Flex-ATX PSU - Old Dell OEM case - Noctua 80mm fans - probably will be windows
Daily Devices:
(work laptop) MacBook Pro 15,4 - i7 4980HQ - 16GB DDR3L - Iris Pro/Radeon R9 M370X 2GB - 1TB SSD - macOS 12.3 Monterey
iPhone 13 Pro Max 128GB - iOS 15.4
then i think if possible i should return my mobo and find a cheaper b350 and 2133 memory . all i want is stable system with maybe 3.7 3.8ghz
yeah , after getting mobo and processor first thing i did is flashing the latest bios .
I think your CPU's the one playing up tbh, but a new board is cheaper so try that first.
Desktop benching:
how to check if my cpu is ok ? sometimes the system is booting with crucial 2400mhz ct4g4dfs824a , which is not on the qvl
that's why I said test with a new board
Desktop benching:
First of all thank you for being such a wonderful support. And sorry for being such a nuisance. You really helped me a lot last couple of days.
Yesterday I was able to stress test with aida64 extreme for more than 1 hour, it was running appx 3.45 ghz with this motherboard and crucial 2400 ram. And after that i tried the test again, now with "stress system memory" and it crashed. And now any stress test crashing. So, what do you think ? How much is the possibility of a bad cpu ?
60%, dying IMC can do that but this CPU isnt that old.
Desktop benching:
I love this motherboard and it works fine with 3000 megahertz Ram
I'm using I'm using a ryzen 2200 G in my htpc
My suggestion is update to bios it should work fine
 Share
