Need help understanding msi rebate system
Solved by Philostic,
1 minute ago, ThatBlockishWay said:I havent bought it yet, I was gonna sort the rebate thing before I did. So say I buy it during the sale, it comes in the mail, then I get the serial: do you think the rebate would still be good since I purchased it during the time of the rebate? I'll check some of my other purchases to see if newegg lists the serial number just in case, if thats the case thatd clear up alot of this confusion...
The mail in rebate will last though the sale. The name implies that you get it in the mail (even if it's online, that's just how they used to work), they're not going to put a time limit on it.
