is 2400mhz enough for a R5 1600?
Solved by NelizMastr,
I'd get the same brand and type of memory for the best results and try to run the sticks at 2666MHz. That should be enough.
zoneeye ·
Posted in Troubleshooting0 -
leclod ·
Posted in Operating Systems0 -
PatRed ·
Posted in New Builds and Planning2 -
1
1
StormBreakes ·
Posted in Build Logs0 -
3
Jojo0607 ·
Posted in Peripherals4 -
1
play_circle_filled
Latest From Linus Tech Tips:
He Spent 3 YEARS Begging me for a PC. Good Luck Finding it!
