Search In
  • More options...
Find results that contain...
Find results in...
TheBritishVillain
Any technical issues going from i7 8086K < i9 9900K with a Z370 motherboard?
Recommended Posts
Posted · Original PosterOP
I am tempted to sell my de-lidded i7 8086K and 'upgrade' to a i9 9900K as it will be quite cheap for me considering how much i'll get for my 8086K. I know i won't realistically notice much performance difference, but would be nice to upgrade to 8 cores whilst i'll still get a decent amount of money for my CPU.
I'm just wondering if there will be any technical issues, as i know the i9's work different in-line with memory speeds (or something?) also i have a Z370 motherboard rather than the newer Z390...
PC specs:
Motherboard: Asus ROG Strix Z370-F ATX
CPU: De-lidded i7 8086K @ OC 5.1 GHz
CPU Fan: NZXT Kraken X62 Liquid Cooler
GPU: RTX 2080 Ti Zotac Gaming AMP Edition
RAM: Corsair Vengeance LED & RGB 32GB (4x8GB) @ 3200MHz
Storage (OS): Samsung 960 Evo 250GB NVMe SSD
Storage (Games): Samsung 850 Evo 500GB SSD
Storage (Other): Seagate Barracuda 3TB 7200RPM HDD
PSU: Corsair HX850i (Platinum)
RAM: Corsair Vengeance LED / RGB 32GB (4x8GB) @ 3200MHz
Case: Phanteks Enthoo Evolv Gunmetal
Monitor: Asus ROG Swift PG258Q
Ought to work fine, but why?
RIP Stan Lee 1922-2018
Managing the new PSU Tier List (Launching SoonTM). Anyone else an electro swing fan?
DIOCLETIAN III : CPU: Core i7-8700K @5.0GhZ || CPU COOLER : BeQuiet! Dark Rock Pro 4 || MOBO : ASUS STRIX Z370-E || GPU: ASUS GTX 1080 Ti Strix OC || RAM: 2 (2x more coming) x8GB GeIL Super Luce RGB Sync || Pile of SSDs lol: 970 EVO 250GB (Boot), 850 EVO 1TB, MX500 1TB | PSU: Corsair RM650x & Corsair Premium cables || Phanteks Enthoo Pro M TG RGB SE|| Monitor: Samsung 28" 4K60HZ ||  KEYBOARD: Corsair K95 RGB Platinum (MX Browns) || Mouse: SteelSeries Rival 310 with XXL mouse mat || Audio: SteelSeries Arctis 5, Blue Snowball iCE || Case Fans : 2x Phanteks 140mm Halos RGB'd fans||
MAXIMIAN II  : CPU: Ryzen 5 1600 @ 3.9GhZ|| CPU COOLER : Cooler Master ML240L || MOBO : MSI X370 Gaming Pro Carbon|| GPU: ASUS GTX 1080 Strix || RAM: 2x8GB G.Skill Aegis (2666) || SSD: TeamGroup L5 Lite 3D 240GB, Intel 545s 256GB || HDD: Barracuda 2TB || PSU: SeaSonic Focus+ Gold 650W w/ Cablemod Basics extensions || CASE: Phanteks P300 Black || Monitor: ACER KG1 1440p 144HZ ||  KEYBOARD: Razer BlackWidow X Chroma TE  || Mouse: SteelSeries Rival 310 || Audio: HyperX Cloud II || Case Fans : 3x Corsair SP120 Blue LED||
LAPTOP - 3XS L15 Vengeance Pro, Incoming : CPU: Core i7-8750H || GPU: GTX 1060 6GB || RAM: 2*8GB DDR4-2666 SODIMM || SSD: 500GB 860 Evo, 500GB 850 Evo || CASE: 15" Laptop - Black || Monitor: 15" 1080p 60HZ ||  KEYBOARD: Laptop keyboard  || Mouse: Probably a Rival 310 (Yes I have three) || Audio: Depends
MARCUS AURELIUS II : CPU: i5-7500 || CPU COOLER : Enermax ET-ST40 Fit || MOBO : Gigabyte Z270XP-SLI || GPU: Gigabyte GTX 1060 3GB || RAM: 1x8GB G.Skill Aegis (2666) || SSD: 240GB TeamGroup L5 Lite 3D|| HDD: WD Green 500GB x3 || PSU: Corsair CX750M || CASE: MasterBox Lite 5 || Monitor: ViewSonic generic 22" ||  KEYBOARD: Razer BlackWidow Ultimate 2016  || Mouse: HyperX Pulsefire || Audio: Not yet || Case Fans : 1x Phanteks case fan, 1x included fan, 1x NZXT case fan
Mobile: Galaxy S7, Honor 7X || Kindle Fire 10" & 7" - Running Android 6.0 ||
Forum salt merchant so granted by @dizmo, Grand Deacon of the Glorious Brethren and Guardians of the Most High Overlords Asus and Arctic Cooling. All hail thy lord and savior the Arctic Freezer 33 eSports ONE
2 more cores for little difference in price. I can shift my CPU for more than what i paid even.
If you want I guess.
Usually the z370 boards aren't as able to handle the power load the 9th gen cpus and cause them to power throttle. I believe it is more of an issue at stock though and has something to do with the default power settings of z370 motherboards. I don't see why you would want to upgrade to a thermal nuclear reactor that even a 240mm AIO can't handle.
nope, their memory controller is still the same so memory speeds should be the same, aside from silicon lottery factor.
VRM temperature could be a concern
Studying abroad, ditched the crappy laptop for a mobile workstation/gaming laptop double WITH CRAPPY THERMAL PASTE THAT 1/2 THE CINEBENCH SCORE
Model: HP Omen 17 17-an110ca CPU: i7-8750H (0.125V undervolt) GPU: GTX 1060 6GB Mobile (1700MHz 0.812V) RAM: 12GB DDR4-2666 CL19 (timings are so loose, might as well have lower frequency). Storage: 128GB Toshiba NVMe SSD (KBG30ZMV128G) + 1TB Seagate 7200RPM 2.5" HDD (ST1000LM049-2GH172) Monitor: 1080p 120Hz IPS G-sync
The best thing to do is reading the clock speed that doesnt end in a pair of zeros. Software voltage readings are wrong if your motherboard's not a high end model
CPU: i7-2600K 4493MHz (multiplier: 43x) 1.35V (software) --> 1.4V at the back of the socket Motherboard: Asrock Z77 Extreme4 (BCLK: 104.5MHz) CPU Cooler: Noctua NH-D15 RAM: Adata XPG 2x8GB DDR3 (XMP: 10-11-11-30 2T 2133MHz, custom: 10-11-10-30 1T 2229MHz) GPU: Asus GTX 1070 Dual SSD: Samsung 840 Pro 256GB (main boot drive), Transcend SSD370 128GB PSU: Seasonic X-660 80+ Gold Case: Antec P110 Silent, 5 intakes 2 exhausts Monitor: AOC G2460PF 1080p 144Hz (OC'd 150Hz) TN Keyboard: Logitech G610 Orion (Cherry MX Blue) with SteelSeries Apex M260 keycaps Mouse: BenQ Zowie FK1
Results: Cinebench R15 Single thread:159 Multi-thread: 770 (thx Meltdown Spectre patch) Super Pi (v1.5 from Techpowerup, PI value output) 16K: 0.11s 1M: 8.4s 32M: 7m 45.9s
Oh do they get quite hot?
Aren't they soldered to the IHS now though? I thought the temps would be great! :/
VRM is a MB component, not a CPU component.
FS / US: (1) EVGA 1070 SC | (1) EVGA 1070 FTW
https://linustechtips.com/main/topic/971428-fs-us-2-evga-1070-sc-1-1070-ftw/
System specs:
Asus X470 Prime
Ryzen 1700X
Corsair Vengence RGB 2x16GB
Crucial MX500 512 SSD
EVGA GTX1080ti w/G12 H115i cooler
BQ! PureRock CPU Cooler
Phanteks P400 Case (no front cover)
Nope they run hot af. Look at some reviews if you want to see. der8auer does a good job of explaining why the new chips are so hot.
soldering isnt magic, it won't compensate the extra 2 cores. In fact because of the increased thickness, soldered CPU doesnt do nearly as good as delided paste CPU.
You need to do at least 1 review before you do this, I think.
Going up 2 cores as you say, but will you even use them?  I don't see any reason for the upgrade, what do you do that will utilize the 9900K besides just wanting to buy something new (which I do as well)?
I think you need to be aware of the issues, and then if you still want to upgrade while being informed... do it ;)
i7 8700K @5.0Ghz - Gigabyte AORUS Z370 Gaming 5Thermaltake Water 3.0 Ultimate - G. Skill Ripjaws V 16GB 3200Mhz - Gigabyte AORUS 1080Ti - 750 EVO 512GB + 860 EVO 1TB M.2 + Toshiba P300 3TB - EVGA Supernova 650 P2 - Fractal Design Define R6 - AOC AGON 35" Ultrawide - Mackie CR5BT -  Logitech G910, G502, G933 - Cooler Master Universal Graphics Card Holder
Honestly with yours delidded and at 5.1 i would say there is 0 reason to switch.
Yeah it seems like staying as i am is the best way to go. 2 more cores would be nice, but just not worth it considering the temps i get now even at max load.
1 hour ago, TheBritishVillain said:
Or you could sell the CPU/motherboard/cooler and get yourself a glorious 12 core system
Where the 12 core CPU is like 220 GBP cheaper than the 9900K...jesus intel why.
PCPartPicker part list: https://uk.pcpartpicker.com/list/HyBFZR
Price breakdown by merchant: https://uk.pcpartpicker.com/list/HyBFZR/by_merchant/
CPU: AMD - Threadripper 1920X 3.5 GHz 12-Core Processor  (£375.99 @ Ebuyer)
CPU Cooler: Cooler Master - MA621P TR4 53.4 CFM CPU Cooler
Motherboard: MSI - X399 SLI PLUS ATX TR4 Motherboard  (£294.40 @ Alza)
Total: £670.39
Generated by PCPartPicker 2018-11-09 22:13 GMT+0000
PCPartPicker part list: https://uk.pcpartpicker.com/list/GQdLfH
Price breakdown by merchant: https://uk.pcpartpicker.com/list/GQdLfH/by_merchant/
CPU: Intel - Core i9-9900K 3.6 GHz 8-Core Processor  (£599.99 @ Aria PC)
Total: £599.99
Generated by PCPartPicker 2018-11-09 22:15 GMT+0000
I edit my posts a lot
Buy VPN
