How Much Cable Length Required For PC RGB
Supahh
I stumbled across this: https://www.gamedude.com.au/products/shop/phanteks-rgb-led-strip-400mm-msi-mystic-light-sync-ph-ledkt_m4s
But it's only 400 mm, and this is my case:
So 400mm could only cover the entire length of the bottum of my case, but most pc's with rgb have the strips on all sides of their case (top, bottum, left and right).
For around $20 - 30, wouldn't you expect it to have around 1m or higher cable length? Or is the strip possibly is bright enough to be placed at the bottom, and visibly light the whole pc?
I'm fairly new to the whole "rgb" scene so it'd be nice if I can be informed with this.
PS: There aren't multiple strips, just the single 400mm strip.
CPU: Intel i7-8700
GPU: MSI GTX 1060 6GB GAMING X
Monitor: HP OMEN 25 144hz
RAM: 8GB G Skill
Motherboard: MSI B360 Gaming Arctic
Storage: 2TB Barracuda
Start-up: Samsung 250GB SSD
Case: Corsair Spec-Omega White
PSU: ThermalTake 750W Fully Modular RGB
Keyboard: Razer Blackwidow Tournament Edition X Chroma V2
Mouse: Razer Deathadder / Logitech G502
Speakers: Logitech Z200 White / Beats Earphones
depends on the quality of the LED strip. you can probably get 2m from china on ebay for about $20, but it's not going to last.
