Problem with Water Cooling my GPUs
So I recently finishing my watercooling loop for the pc I built not too long ago. This is my first time water cooling and I can say it went pretty well...until I looked at the temps of my gpus (Two ROG Strix GTX 1080s). The top was hitting temps of 170 F on idle, while the bottom one was sitting at a cool 86 F on idle. I do not know how to fix this. I for sure know that I put the water blocks on correctly since I went step by step with the manual. I would love to start overclocking the gpus but this has been a problem I cant seem to fix. I don't understand why the water is bypassing the top gpu water block. Can anybody help?
Watercooling Parts:
EK-CoolStream SE 240 (Slim Dual)
EK-CoolStream SE 360 (Slim Triple)
EK-XTOP Revo D5 RGB PWM - Plexi (incl. sl. pump)
EK-RES X3 250 RGB
EK-FB ASUS M9H Monoblock - Nickel
EK-FC1080 GTX Strix - Acetal+Nickel (2)
EK-FC1080 GTX Strix Backplate - Black (2)
EK-FC Terminal X2 S 3-slot - Acetal
EK-CryoFuel Clear Concentrate 100 mL
EK-ACF Compression Fittings (12)
EK-ATX Bridging Plug (24 pin)
EK-AF Angled 90° G1/4 Black Nickel
Have you checked to make sure that the heat pads are all seated correctly and the block is making full contact?
3 minutes ago, Firewrath9 said:
Its his post so he should get a notification.
no i did that to give you a notification for what OP said above me.
She/Her
1 minute ago, whitledgeholden said:
Here it is.
It looks fine, mabye reseat the waterblock for the gpu?
Ive tried this also. I cant seem to figure out why it bypasses it though. Its strange.
I have decided to let the pump run and to see if there is any air bubbles that may be causing this to happen.
Here is your problem. Look at the instructions and look how you installed it.
Main RIg Corsair Air 540, I7 9900k, ASUS ROG Maximus XI Hero, G.Skill Ripjaws 3600 32GB, 3090FE, EVGA 1000G5, Acer Nitro XZ3 2560 x 1440@240hz
are you running the GPU in serial or parallel?
it looks parallel, but the block could be setup as serial
But the weird part is that water still goes the bottom block. Does that matter
Yes I'm running it in serial
If its a serial block, you aren't running it correctly. As the picture and instructions clearly show.
alright thanks man
