Question about ethernet over power lines
Marco2G
Hi everyone
I live in a six apartment building and I've connected my workshop in the basement to my network on the third floor via a powerline bridge.
Now I'd like to be able to open and close my garage door via app. When I bought the TP-Link powerline adaptor set back when, I tested whether it'd reach my garage and I remember it managing albeit at a pretty bad bandwidth. But for this? Who cares!
Anyway, I replaced my garage door motor and today I wanted to IoT the sucker. Unfortunately, I get no connection anymore.
Now tl;dr:
Since my workshop is way closer, I was wondering whether the powerline adaptor there would act as an intermediary to extend my range. Problem is I cannot just buy a third adaptor... they're only available in a set of two and I'd hate to spend 150 bucks and then it doesn't work anyways...
9 minutes ago, Marco2G said:
-snip-
You could try. Powerline uses the building circuitry so its hard to say for sure whether or not it'll work.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 17.2.1) | iPhone XR (iOS 17.2.1) | iPad Mini (iOS 9.3.5) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
Which is exactly why I'm asking if anyone has experience in this matter.
Power line is all about distance between point A and B. Power line adapters were originally created to work on a single circuit. The newer ones can cross the breakers but there is a cost. The more breakers and the greater the range you WILL have interference. Not sure where you live but here in the US the power company bring 220 in to the house via 2 110volt cables. Each 110volt cable connects to one side of the breaker panel. This is an issue if both locations are on different main wires. Because then the signal has to go out to the meter and this can be hell for it.
So the only thing you can do is try. If it dont work, then you know.
Here in Switzerland we have three phases. I will try whether the garage might be on a different one than the apartment and the workshop.
I just tested from the workshop to the garage and that worked fine. So I will buy another set of adapters and hope they actually do work like the graphic on TP-Links website implies :D
Exactly like what you said.  For your use case, who cares about performance.
I used ZyXEL PLA5206KIT Ethernet over Powerline for good couple months.  The performance is not deterministic, sometime it could be okay and sometime it's unbearably slow.  And what adds to this un-deterministic is that sometime the powerline adapter would just stop working and I have to power cycle it (unplug and replug) the adapter.
I guess a fair warning that don't be surprise if one evening you cannot get into your garage because the adapter stopped working.
