No Wireless & No LAN Adater Detected Father's Day build HELP
Solved by Nauthes,
RESOLVED:
For anyone looking for info this is how i resolved mine.
Go to search type device manager.
In my case i had nothing under network adapters
However i noticed under "other devices" there was unknown network device
Right click on unknown network device
click update driver software
click browse my computer for driver software
hit browse and select C: drive
hit next
It auto detected a wireless network driver i clicked finished and wifi started to work right away
Then i attempted to install the Wired LAN connection driver from the motherboard manufacture and it installed LAN driver LAN started to work after a reboot
Thank you guys for trying to help
