Help choosing a monitor
Synth3D
I am looking for a gaming monitor with excellent colour reproduction and I have noticed that many of the freesync monitors have excellent panels, VA or quantum dot technology. The only other alternative would be to find a G-Sync monitor with a VA panel but they seem to be a rarity.
https://www.msi.com/Monitor/Optix-MAG27CQ
Excellent contrast ratio and colour reproduction but my concern is the refresh rate. If I buy a freesync monitor, will I be able to take advantage of the freesync feature if I have a Nvidia card?
I have also seen the Acer Predator XB271HU G-Sync 165Hz monitor with an IPS, how does it compare to a VA? Will it have the same level of colour reproduction?
Thank you.
No you will not, only AMD.
In general if both are quality panels, an IPS display will have a slightly better color reproduction and viewing angles, but a VA will have a superior contrast ratio.
There's a time and place for everything! But not now. - Professor Oak
i7 2600K 4.3GHz  -  GTX 1060 3GB  - ASUS P8Z68-V - 16GB DDR3-1600 CL9 - EIZO 1080p 120Hz VA
Intel Skulltrail: 2x Core 2 Quad QX9775 - Intel D5400XS - 16GB FB DDR2-800 CL5 Quad Channel
EVGA SR-2 Classified - 2x Xeon X5675 4.2GHz - 24GB DDR3-1830 C10 Triple Channel
Intel Skulltrail #2: 2x Xeon E5472  - Intel D5400XS - 16GB FB DDR2-667 CL5 Quad Channel
If that is the case, I could always cap the frame rate with RTSS depending on the individual performance of the game.
Do you know any G-Sync monitors which have a similar VA panel and spec?
https://www.amazon.co.uk/LG-32GK850G-B-computer-monitor-monitors/dp/B078TTXLW5#customerReviews
I have found this LG monitor but the reviews state it doesn't have the same coloration as the Samsung panels. Is it worth waiting for the HDR monitors instead?
What about this one?
https://eu.aoc.com/en/gaming/products/ag352ucg6
I'm not exactly a monitor expert. Freesynch and gsynch are pretty basic stuff. You'd be better off getting someone else.
