!Help! Downloads Shortcut Is Now The Same As Data Drive Shortcut
Archivic
I accidentally linked my downloads shortcut to be the same as my D: drive shortcut, how do i unlink?
Edited by Archivic
edited for -hopefully- better clarity in what i need help with
I didn't even know Windows could let you do this. Did you check if it'll let you delete & remake it or remap the shortcut? Either should fix the problem.
It wont let me delete it, and when i try and go into propertys to remap the thing, it gives me an error message
Do you recall the steps that brought you to this conundrum? Might bring some insight on how to fix it.
Was watching this video
I forgot to make a downloads folder and it used the default D:/
If you click on the D:\ drive > properties does it give you the Location tab and the option to remap it to the actual D:\ drive?
