saitias
Strix 1080 TI Fan Stuck in Max Turbo Awesome Speed
Recommended Posts
Posted · Original PosterOP
Hi Guys,
Hoping you can help me out here. I just purchased a new Asus Strix 1080TI (non-OC'd) and I seem to be having a lot of issues with the fans on it.
I got this card cause I kept hearing about the larger heatsinks and three fans so it'll stay nice and cool, as well as super quiet. Doesn't seem to be the same thing for me though. . .
From boot, the fan, over the power connectors, is at max RPM, even when the thing is with load in a game, the other fans are not even as loud. That is how loud the first fan is.
Some info for you all to see if you can assist. I'm at my last straw as I wanted to build a quiet rig.
HARDWARE
ASUS Strix 1080Ti Running Driver 390.65, and vBios of 86.02.39.00.AS15
AsRock Z370 Taichi
Triple RAID m.2 NVMe for boot
Corsair x750i
Corsair 115i aio
2 case fans, linked to motherboard
Software:
Windows 10 64bit
Asus GPU tweak 2, V1.6.0.5
Corsair Link 4
Other Data:
GPU fan speed reading at 3628, 1 fan on (over power connectors) and other two are off at "idle"
GPU Temp at 33c
MB Temp 37c
CPU temp 34c
List of things I've already tried:
Turned off PC, unplugged power, tried to reseat the graphics card
Created Custom Fan Curve in GPU Tweak 2 - I can get the other 2 fans to spin up by setting to max 100% at 10c and then turn back off, but 1st fan doesn't change. (so looks like software is at least communicating?)
Uninstall /reinstall GPU Tweak 2
Uninstall / reinstall nVidea Drivers
ANy ideas you guys have would be helpful!!
Regards,
Looks like one of the fans is bad. If the card is under warranty, you should be able to contact Asus for a replacement.
  • Recently Browsing   0 members
    No registered users viewing this page.
