Power Splitters, 3pin & 4pin
JaegerB
So I bought my new H500P today, and I have three Masterfan pro 120 RGB air balance fans to put in it for exhaust.
The stock fans it comes with are the two 200mm RGB fans and a shitty stock 140mm.
My motherboard is the X370-F, and it has 3 4 pin chassis fan connectors. These are fine for the masterfan 120s, but I don't know how I'm going to connect my two 200mm fans with 3 pin connectors.
Do I need some form of adaptor?
I would appreciate it if someone could let me know what kinds of adapters I need.
To recap, 5 fans (three take 4 pin power, 2 take 3 pin power) and three 4 pin Chassis fan connectors.
Cheers,
Jaeger
EDIT: What about a fan hub?
HEADS UP, THIS ACCOUNT IS INACTIVE NOW
I'm keeping everything else the way it was for anyone who might check out my answers in future, but I won't be using LTT.
Don't forget to quote me when replying to me!
Please explain your question fully, so I can answer it fully.
PSU Tier List Cooler Tier List SSD Tier List  My Specs Below!
My PC:
CPU: Ryzen 5 1600 @ 3.2GHz
Cooler: Stock Wraith Spire
RAM: G.Skill Trident Z RGB 3000mHz 16GB DDR4 (2x8GB) RGB
Motherboard: Asus ROG Strix X370-F Gaming ATX
SSD: Crucial MX500 500GB 2.5"
HDD: Western Digital Blue 1TB 7200rpm
GPU: Asus ROG Strix OC GTX 1060 6GB
Case: Cooler Master H500P
PSU: Corsair RM650i 650W 80+ Gold Fully Modular
OS: Windows 10 Home 64-bit
Fans: 4x Cooler Master Masterfan Pro 120 Air Balance
Potato Laptop (Samsung Series 5 Ultrabook, 2013):
CPU: Intel Ivy Bridge i5 3337U @ 1.8GHz
RAM: 8GB DDR3 2133mhz SODIMM (1x4GB Samsung, 1x4GB Kingston)
SSD: Kingston 24GB SSD (originally for caching)
HDD: HGST 500GB 5400rpm
GPU: Intel HD 4000 Graphics
fan controller for the masterfans and fan splitter(s) for the 3 pin ones
Ryzen 5 3600 stock | 2x16GB C13 3200MHz (AFR) | GTX 760 (Sold the VII)| ASUS Prime X570-P | 6TB WD Gold (128MB Cache, 2017)
Samsung 850 EVO 240 GB
138 is a good number.
Thanks, I'll use the fan controller for the masterfans. I haven't been able to find a 4pin to 3 pin adapter on ebay or any australian online stores. Any suggestions?
My PC:
4 pin means pwm, better control over fanspeed
3 pin means voltage, not much control over fanspeed
you can plug 3 pin into 4 pin, or 4 pin into 3 pin, its best to pair 4 pin with 4 pin and 3 pin with 3 pin (mainly because you don't want to waste a 4 pin header, not because 3 pin works any better on a 3 pin header)
Except when it doesn't.  My motherboard has a 4-pin connector that isn't PWM.  It's the most annoying thing ever.  It made me really mad.  The lowest I can turn a fan down to is 50%.
Make sure to quote or tag me (@JoostinOnline) or I won't see your response!
PSU Tier List  |  The Real Reason Delidding Improves Temperatures"2K" does not mean 2560×1440
Oh thanks, I had no idea. Guess I learn something new every day! Ok, so I'll give that a shot. If that's the case, I mightn't actually need a splitter for the 3 pins, since I can plug the fan hub into one of the three chassis fan headers and the two 3 pin fans into the other two chassis fan headers.
My PC:
